Brand New Nissan Gtr 35 With Paint Defects Over Two Days
PolishDoc
 Share
  • Replies 90
Posted Images
Nice post with lots of helpful info.
Cheers. :D
Yeah i was referring to both of you actually.
Youve both been very helpful.
Its not every day we get a thread on paint care... :)
Ok guy's,
I've been extremely busy so that's why i am responding to you now !
I am also getting ready for next months trip to Sydney, jobs, meetings etc....
The GTR 35 was clayed down extensively and no i didn't take any PTG reading's because i thought that the PO 106 FF would not remove enough paint to
warrant a reading . With the paint correction i did i probably removed less than one micron .
I would have however taken PTG readings had i used Menzerna Power gloss, or PO 85 RD 3.01 with a wool pad or similar combination , any other questions ?
Paint technology is changing so rapidly that i have always kept up to date with the latest Technology and this is just the beginning !
I have been testing new polishing compounds which use nanotechnology ( Not Sonax, or Menzerna ) .
Sorry, i can't disclose the product's name at this stage until it's released to the Australian market and further testings are done plus .
That's just a taste of things to come so be patience i will keep you informed !
Regards Mario :D
Daniel,
even though you are using a forced rotation machine, you're using Final Finish, how much clear do you think you'll be removing?? :D
Interest to hear your thoughts re: 106FF choice for BOTH polishing stages? And given the car is jet black, why not finish on CCS Black
One thing CCS Black does not cut like CCS white and when you are left with fine blooming on the paint ( very fine haze)Black CCS will not correct that problem !
Don't be fooled by less power of a Flex forced rotation machine , it will do some serious damage like a rotary, i have tested this machine
for a solid month before i committed myself to putting my money down .
And to further prove my point here is the full review i wrote on the Flex http://www.detailparadise.com.au/modules.p...opic&t=2912
Enjoy !
Regards Mario :)
Hey Guys,
Just got the news today ! :D
Got another New GTR 35 to polish in six to nine weeks time ! :D Not sure if it's going to be another Jet Black or a Titanium Metallic !
I will keep you all posted :(
Regards Mario :)
  • 10 months later...
Hey Mario
NICE WORK ON THE GTR! I figured you are the best person to help me with my question
Have a look at the pix, I recently found these bubble like bumps on my bonnett, they feel like as if something is underneath the paint.......do you know the cause of this? how do I fix it?
the paint is still under warranty, is this something that the warranty normally covers?
thanks in advance for your advice :D
don't think even wetsanding could help you there... but could be wrong..
and dude, how the hell are you washing your car?? if this is a new R, the paint is hammered! :D
Hey Mario
thanks in advance for your advice :)
Lj,
The photos show me some thing but i need to see the car ?
Perhaps wetsanding might get those defects out , but i also need to do PTG ( Paint Thickness Gauge ) measure the paint film build .
Send me a PM please .
Regards Mario :D
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
