My friend had one on his car and I wouldn't have called it silent that's for sure. You could hear him coming from a mile away.
On the road both his and my R33's performed very similar with nearly identical mods. The difference was I had a HKS Super Dragger. Mine was much quieter especially low and the performance up top appeared to be basically same.
So, the HKS Hi-power Silent was a good exhaust and sounded pretty good too. In the end it just created too much attention and wasn't as nice to live with every day so he sold it. He felt like every second person was going to call the EPA.
I run HKS Silent Hi-Power exhaust on my R34. LOVE IT.
It's quiet enough for a very free flowing exhaust. I think I sit on the dB limit at idle. Obviously it's a little louder when you're on throttle but I am running some mods that don't help that situation.
Cheers.
I am running one on my R33 full 3inch system and high flow cat with about 340hp atw.
As said already they are not silent by any means. They give off a very nice RB tone.
I don't think there would be any power loss unless you go a size that's too big for your set-up.
So any upgraded exhaust system will usually be much better performance than a stock set-up exhaust.
So basically if your after a nice tone and have the money to spend on one then they are a nice exhaust, But if your already running aftermarket exhaust and you are happy with the tone you already have then i wouldn't bother spending for a small gain if any. You could spend money on a better flowing high flow cat which would probably give you a better gain.
Hope my 2 cents helps you out.
Cheers
Nothing wrong with the HKS Hi Power Silent...as said...they still flow well...just that they have spent time to engineer a proper exhaust that keeps the noise down...
I went from a loud as custom exhaust with a cannon muffler to a quiet trust system and picked up a few kw actually...quiet doesn't necessarily mean restrictive...
As everyone has mentioned above. Hard to question HKS's workmanship. You will without a doubt notice incredible gains coming on boost when added to a hi flow cat and front/dump pipe.
Don't get the HKS Silent Hi Power confused with a aftermarket exhaust that has a removable silencer. Those are what cause restrictions. If you pick up a HKS silent you won't find a silencer shoved in there.
m2c
Cheers.
Jeeeesus. If you sit on the Db limit at idle, thats pretty loud. The Db limit is supposed to be at 75% of peak power rpm; so 5500 rpm or something like that.
Shaun.
I got one on my 32 gtr.
I personally think its too quiet for me... it does have a nice idle tone to it.
I dont think cops will ever pull me over for the noise tho.
My hks hipower silent catback also has the hks front pipe with stock dumps..
I only noticed a big difference when i changed my catalytic converter (since my old random jap catback had rusted) to a 3.5inch hi flow one....
Gotta hate compliance cats :(.
I have an HKS silent series exhaust and I like it. I don't know what my "gains" are, but it is a very nice system for my car as it is a DD and I don't want to be obnoxious. My car came with it from Japan, but I also got a down pipe and a test pipe when I got it here and that made a difference in sound (little louder and deeper) and turbo also spools a bit quicker.
The only reason they named it silent is because they have added a small hotdog resonator in the pipe as opposed to the standard hks system which has none. So really it's not in reference to it being so quiet no one can hear you it's just they have added this little piss ant thing in to make it a little more street friendly than a straight through pipe. In terms of power gains, unless you will be running a big hp car I doubt you'll run into exhaust restriction problems.
Hi there,
Yep bought a hks hi power silent for my gtst running the 2835 pro s turbo kit. Way too loud - drove it round the block and took it off - sold and bought a trust PE 2 (Power Extreme 2) - it's much quieter and the car makes about 260 - 270rwkw.
The hi power silent sounded like a race exhaust in comparison and you'll get too much attention from traffic police - don't forget though that stock turbos bring the noise down in comparison to larger ones.
Hi there,
^^^^Yeah, thats important to remember.
There is no point in comparing a car with a single highmount to a car with smaller twins (or single), as the turbine housing size makes a massive difference to sound. I remember when i changed from a 0.82 ar to a 1.06 ar and, with everything left the same, the exhaust note from the 1.06 was significantly louder.
Shaun
Shaun.
True but with my setup, there's not much I can do to bring the noise down under load. I just have to deal with it. Unless I start shoving in silencers and no one wants that! To be honest, I don't think it's quite at 92dB at idle but it would be close.
Cheers.
    • Curious if you've discussed this with them, maybe they can remove it for you since you requested it not to be coated.
    • Thanks Rezz...   👍
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
