NOOOOOOOB
the firewall is the wall that seperates the engine bay from the cabin of the car
geez don't have to be rude. :P
I was basically asking which grommet to thread the wiring through.
(Viet boy) has assisted me with the installation.
So all is well.
Gimmi your front bar n I'll wire it for ya :(
there is a section of the 'carpet' on the drivers side behind the brakes you can remove
where there's a circular metal section behind it which you can drill out if your wires isn't long enough
Edited by POLICE
feed the wires from the engine bay through the hole at the back left (driverside) of the engine bay, this will mean the wires will go down into the driverside wheel arch. u will then have to take off the plastic shield around the wheel arch, then pull the wires through.
then u can stick them through the accellerator cable from memory, and thats it, your through.
Thanks for that
I will do that tonight.
Appreciate your answer
Cheers
needlessly harsh
OP, howd it go?
I followed r33cruiser's method and got it done but it was a awful process. I mean if I had a better jack that lifted the car higher i wouldn't have to squeeze my hand and cut my myself trying to poke a coat hanger through the hole. etc etc
was it worth it? not really
hah
youre a real mechanic now =D
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
