I have most of the interior parts for a R32 GTST. i will be adding more parts up once i pull them out. Most of the bigger stuff i am only willing to do pickup, or i can deliver if its not to far out of my way and for a small fee. If you want anything not on my list shoot my a pm and i'll see if i have it.
Center Dash Vent ~ $60 (i am willing to post this item, at buyers expense)
the vent is in good condition over all. the front surrond is in one piece and all the clips are intact. the only thing wrong with it is one of the horizontal fins has broken off the adjustment bit. it still sits straight and you can adjust it with your finger so it sits straight. See pic.
Passenger Dash Vent ~ $25 (i am willing to post this item, at buyers expense)
this vent is in ok. the the vertical deflector parts have broken off the adjustment bit. the surround is in one piece but the two bottom clips that hold it onto the vent body are broken. but even with them broken it still sat ok in the rest of the dash. See the pics for more detail.
R32 Turbo Timer Loom Universal ~ $15 (i am willing to post this item, at buyers expense)
This loom plugs in between where the ignition barrel plugs in and the main loom. about 200mm from the ignition barrel. Saves you from cutting into you original loom.
R32 Double Din Cd Player Mounting Brackets ~ $10 (i am willing to post this item, at buyers expense)
the two brakets that let you mount a cd player and other din mountable equipment.
R32 Digital Climate Control ~ $50 (i am willing to post this item, at buyers expense)
Standard R32 digital climate control, good condition, all buttons work and unit itself works fine. Comes with the plastic front cover and i can also include the electrical plugs with some of the loom if you want.
R32 Drivers Side Window Controlls ~ $50 (i am willing to post this item, at buyers expense)
the drivers side controlls for the windows and mirrors, all the switches and controlls working.
Power Window Relay ~ $25 (i am willing to post this item, at buyers expense)
The black box located under the door card on the drivers side door that controll both the drivers side and the passenger side window functions. Its out of a 32 but i think a few of the nissan models are the same (S13, R33 maybe).
R32 Instument Cluster ~ $100 (pick up only on this item please, for the moment)
Grey back GTST, Manual, non-ABS model instrument cluster with 129k on the clock. All gauges worked fine and cluster and all mounts are in good condition.
R32 Projector Style GTST Passenger Side Headlight ~ $100 (pick up only on this item please, for the moment)
Headlight in good condition, no damage to glass or mounts.
EBAY Job Short Shifter ~ $25 (i am willing to post this item, at buyers expense)
as it says it an ebay bought C's style short shifter. i had this in my r32 for a couple of months. the little white bush fits in the g/box well.
More to come.
Edited by QWK32
https://www.sau.com.au/forums/topic/227221-r32-gtst-interior-parts-brisbane/
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
