Hello,
I got a pair of T517z 8cm turbos for the R32 but I don't know what to do.
It only oil cooled so what do I need to do with the water on the block when I take off my standard turbos off. :D
Anyone can help me?
Thanks in advance.
I think u need oil otherwise your turbos will seize!
You probably have to block your water lines, cause i know a few if not most trust turbos are not water cooled.
Anyway just take the bolt from the water line that goes into the block to a place like pirtek and they will give u a bolt with the same type of thread that u can use to put into the block and that will do the job. Then u have to worry about blocking off the other water line too.....
Not sure wat u mean about the turbos sitting opposite?
Good luck!
Edited by shAkIeL
1. Drain coolant
2. Remove air filters/afm's, piping etc.
3. unbolt front pipe.
4. Remove your stock turbos, and lines. (some are underneath the car)
then.
You buy a bolt/plug for the water return on the block around (19mm) in size.
Then u need an additional 2 plugs/bolts for the water lines that run behind the engine that merge next to the abs unit (12mm, 17mm?).
And then u also need to block off the rubber water line/hose that runs at the front of the engine with a bolt and a clamp.
Then install turbo as normal.
I'll try and dig up that guide as i promised you.
Tai
it come swith standard dumpe and lines. no braided or nothing. It is a used kit :ermm:
Please take some photos for me that would be appreciated :D
tai- that would be great mate :)
