Hi guys, Im looking at 19x9.5 inch wheels with +12 offset for my R34 GTR.
What tyre size would I be looking at exactly?
I want to make sure that the tyres would be 100% street legal for NSW ie: overall rolling diameter, speed and load rating, making sure that the tyre is allowed to go on a 9.5 inch wheel etc.
(load and speed rating for my stock 18x9 inch wheels is 93W 245/40/18 but the sticker on the door says they only have to be 89H or better)
Thanks
you will have no problem on a GTR34 fitting a 265/35/18 road tyre.
candy33 may be referring to a gtst rear fitment.
No i'm referring to a gtr.
I have owned several gtr's and can tell you with that offset and width you cannot run 265's without lipping the guards.
Thanks
Hey buddy, ive got 19x10 +19 on my r34, it sits in a bit at the rear and i have wider front guards so its flush.
with a 275/30/19 it sits flush on the 10" rim, 265/30 stretches slightly, but i would go for a 275 as its closer in rolling diameter to the 245/40/18, plus it looks tougher!
(thats what we put on all the 19" GTR's we do, havent had to roll the guards on an r34).
an 89h is easily superceeded in 275 so as far as load/speed ratings, rolling diameter, and wheel track go, its legal.
I have some dunlops in that size going cheap so pm me if your interested mate.
Rubbish - you can run 265's on an R34 GTR easily.
On a 9.5" rim 265's are as wide as you want to go though.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
