Recently I've noticed a few annoying noises in my car which I can't place and don't have the technical know-how to fix. Basically theres a rattle from the rear parcel shelf and a high pitched squeak coming from my passenger door when driving over moderate changes in the road.
These are really starting to get to me and was wondering if theres someone out there who can hunt out and fix these problems.
I'd assume in this day and age there would be people who specialise in sound deadening of sorts, stopping rattles etc. Any ideas ? Located in the Sydney area.
It's just too hard to try and find the problem yourself whilst driving to try and create the situation where the noise occurs ...
https://www.sau.com.au/forums/topic/22726-things-that-go-bump/
hey i just bought a 180.. well couple of months ago came with a whole heap of gear one thing a after market clutch.. buggered if i know the brand of it is but i know it must be heavy duty coz my leg gets a hell of a work out. hey and do you know how i can find out what kinda unit it is without pulling the bitch out.. but hey ive got this problem when i drive the car kinda easy ( hey what am i talking about you dont drive a drifta easy ) ok anyway.. it kinda goes klunck as i let the clutch out but when i drive the car and give it a little stick there's no klunck.. so there klunck and no klunck but mostly no klunck.. what do you guys think
That's just a heavy duty clutch for you ... depending on what clutch it is it's probably a button clutch tho, so either on or off.
The reason it's going clunk is because your trying to ride it and not giving it enough revs. Atleast thats what I've found, same thing happens to me sometime when I'm entering my complex at 5am and trying not to wake the neighbors .. it's just the pickup, sounds like somethings about to fall off your car eh :)
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
