Recently I've noticed a few annoying noises in my car which I can't place and don't have the technical know-how to fix. Basically theres a rattle from the rear parcel shelf and a high pitched squeak coming from my passenger door when driving over moderate changes in the road.
These are really starting to get to me and was wondering if theres someone out there who can hunt out and fix these problems.
I'd assume in this day and age there would be people who specialise in sound deadening of sorts, stopping rattles etc. Any ideas ? Located in the Sydney area.
It's just too hard to try and find the problem yourself whilst driving to try and create the situation where the noise occurs ...
https://www.sau.com.au/forums/topic/22726-things-that-go-bump/
hey i just bought a 180.. well couple of months ago came with a whole heap of gear one thing a after market clutch.. buggered if i know the brand of it is but i know it must be heavy duty coz my leg gets a hell of a work out. hey and do you know how i can find out what kinda unit it is without pulling the bitch out.. but hey ive got this problem when i drive the car kinda easy ( hey what am i talking about you dont drive a drifta easy ) ok anyway.. it kinda goes klunck as i let the clutch out but when i drive the car and give it a little stick there's no klunck.. so there klunck and no klunck but mostly no klunck.. what do you guys think
That's just a heavy duty clutch for you ... depending on what clutch it is it's probably a button clutch tho, so either on or off.
The reason it's going clunk is because your trying to ride it and not giving it enough revs. Atleast thats what I've found, same thing happens to me sometime when I'm entering my complex at 5am and trying not to wake the neighbors .. it's just the pickup, sounds like somethings about to fall off your car eh :)
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
