Stock r33 and it splutters
Guest IHaveAnR33
i would love to go full engine management system, but too costly for now... i just want to get the car running smooth on standard boost. the boost restrictor has a couple of wires connected to it i never disconnected them just disconnect the hoses. should i disconnect the wires as well?
Dood please dont read some threads on this forum and then start to fiddle with things. After you read somethign interestingl ike a free boost increase and you are really excited about the MORE BOOST aspect that most owners are into. Then first try and find more threads on how all the different parts work that are involved in causing the car to boost etc. then you can do what you like and you will have a fairly good idea about what damage you can cause.
It sounds like you are grasping for cheap mods to do. DONT unless you are sure.
SAFC took me about 1 hour to install. and then i counted 1 wire incorrectly and the car wouldnt start. took me a further hour to find and fix that.
so yeah workshop is your friend in your case, but if you got plenty of time and passed year 2 maths (unlike me) it wont be a problem to install.
peace
Your R33 only uses coil packs.
For the spluttering issues, it will either be spark plugs or that a coil pack will be faulty, which will cause a misfire.
Please don't start pulling random hoses and such off the wastegate actuator without properly regulating the pressure, unless you would like stuff to start breaking?
The stock fuel system will run very rich so there is no need to worry about underfuelling, if anything get it tuned with an SAFC (or any decent piggyback or complete ECU replacement) like GTS-t VSPEC suggests.
It is all tuning.
    • Hey all, It's been a bit since I have been able to update.  I pulled the fuel pump, first off it was a "universal" pump and the strainer was very clogged, and it was folded over on itself.  I replaced the fuel pump and all is well....  No more stalling.
    • That's convinced me I'll bump up the G30-660 to 770   Any idea if the difference in boost pressure? Cheers
    • When: Saturday 24th of May 2025 - All day Where: Sydney Dragway, Eastern Creek Cost: Varies - Book direct with the GTR Festival Website We will be there on the day with a stand please reach out via our interest form if you wish to help out with the stand. Limited parking will be available in the display area, first in first served with current members getting priority, please register your interest with the link above also. Please post any great photos you take on the day on this thread and we will try use some in our e-mails/website/social media
    • Hey guys so turns out this project is going to be much bigger than I thought haha but I've done some my homework and have done a few panels on my car, but one part I can just not visualise is this. If I do a spot repair and I put filler in a dent for example and sand outside of the repair with 320 grit lets say so the primer can stick as I will only put primer on that repair and the surrounding area and then repaint the whole panel. Don't I need to make sure that I don't put primer on the old clear coat? I keep seeing YouTube videos where people have new paint and primer land on the old clearcoat that isn't even dulled down, it's still shiny. I thought putting paint on clearcoat or primer on clearcoat is a bad idea because it won't stick. So in this scenario it's a bit different to mine but imagine someone doing a spot repair and only painting that small section of repair but the new paint is landing on the old clearcoat. What am I missing?
    • I was immediately reminded that your location is QLD. Sounds like a perfect SEQ business idea.
