umm they look like normal m spec skirts :s they are white, i pod has a bit of damage but its on the inside so cant really see it and 1 skirt has a small crack up the front.
example http://i7.photobucket.com/albums/y276/siddr20/ok2-1.jpg
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
