Any 1 Put Rb20det Head On Rb30e Bottom End?
G'day guys i have my Rb20det with blown rings
and a RB30e block with new rings and bearings
Can I mate them up?
I want to keep my loom and ecu can i still do that if i get a rb25na r32 head?
cheers
its A31 cefiro btw
Can I mate them up?
cheers
its A31 cefiro btw
No, you can't mate up the RB20DET head and RB30E block - but (I may be corrected here) I'm pretty sure you can use your loom and ECU with the RB25DE head. I assume you are using an aftermarket ECU for this?
Yes you can mate it to the RB30 block( it has been done numerous times before ) , it isnt as straight forward as an RB25 head.
It is a pointless exercise though as there arent any real gains using the small post small valve RB20 head.
The RB20/RB30 heads flow about the same.
So no point, might aswell stick with the RB30 head and valve/cam that, cheaper too when there are only 12
RB25 head is what, 30% more flow in stock form, hence why its used.
RB20/30 simply put is a waste of time and money. Everyone that has done it would never do it again.
100% agree, we did it before RB25/26 heads were readily available at reasonable cost. The required welding and machining of the RB20 head makes it far more expensive than simply bolting on an RB25 head. There are lots of issues with running an 86 mm bore into a 78 mm diameter cylinder head.
Cheers
Gary
Yeah I guess I could have said that but decided easier just to say you can't, much the same as technically you can't use a solid piece of alloy as a head :)
Yeah I guess I could have said that but decided easier just to say you can't, much the same as technically you can't use a solid piece of alloy as a head without a bit of modification :)
  • 6 months later...
Cheers
Gary
that being said... if you had a rb20det head that already had the mods performed to it and you wanted a cheap project would it be worth it?!?
ive seen a stock rb20 head flow 375rwkw with the right turbo so i cant see it being too much of a restriction for say 300-330rwkw
letme know when you want to come pick it up simon haha
my car came fitted with a 30/20DET combo from japan, we've had the head side to side with a stocker and the only visable mods were machining out the water galeries to mate up to the block
stupidly responsive but never got a chance for a dyno run with it all
 Share
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
    • And over it. Need to stop it coming through the floor.
    • Is it running the standard ECU? some sort of data log might help understand where timing, AFRs etc are at.  If it is standard ECU something like Nissan Datascan would help
