  • Replies 329
hmmm epa... oh what a pain, i usually change pipes at the track :thumbsup: grrr, might have to leave my street pipe on! (95db from 30m so that is race car loud, not street legal)
Edited by Dave R
i want to pay for me and another friend who should be getting his evo 6.5 by then,,,,, is the evo allowed seing as it will probably whoop most of our assess lol,,, much like that little honda will if it does the things the owner says it does... and it looks like allot of people are intersted in this event.... will i get a spot? also i was one of the first to show interest in the event on this forum..... im so excited im going to loose my texikhana virginity
Where do we scribble out names down for a CAMS licence?
CAMS L2S/L2NS application form
Print it out, fill it out and send it to them. Takes a couple weeks from memory to get it so do it sooner rather than later if you do it this way. This is what I did for Wakefield.
Either that or fill it out, bring it to Texi and get a SAU Exec to sign it. You'll get a temporary CAMS licence while you wait for the real one to come in the mail.
Is it possible to use a L2NS, or would I need a L2S?
I might head down with Cassbo and take my E30 bmw for a spin (thats if eurotrash is welcome :))
Yep, Because it's a "Non- speed event" your L2NS will cover it for the day :huh:
Hey guys,
Sorry it took so long but here is the link to the entry form.
Linky
Once you have submitted your entry form some options will come up to pay with paypal if you choose to use that method.
Direct EFT is still available.
Any problems please send me a PM.
Cheers,
DIF
Just a reminder guys. We can take AASA and CAMS on the day.
You will need to be a member of a CAMS affiliated club for the CAMS L2S but we will have membership forms on the day.
:blink:
just to add to this, SAU NSW (the club not the forum) is a CAMS affiliated club incase you were not sure about that part :ermm:
so as Corinne said you can join our club + apply for the AASA or CAMS on the day :D
Guest
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
