Hey peoples,
I got a 93 r33 gtst, its got a 3 inch exhaut and a k&n pod filter among other things but they are the engine mods that im aware of. It has a greddy boost controller-just the turn dial one from in the engine bay. Whe i got it i knew that the boost was tweaked abit and have since been playing with it abit. I was having problems with it and people have told me that what im experiencing is boost cut!!! If i was cruizing along in 3rd at round 60 and then plant it once it hits between 3 and 4 grand it jolts and comes good then jolts and so on. So i turned the boost down 2 notches and tried again, still happening, so another 2 notches and now it doesnt do it but there is a major difference in power now. I mean on a cold night it was pretty good at the previous boost levels aslong as i stayed above 3500rpm in 3rd 4th n 5th. So on the highway it went really well but round town i notice the stuttering more so now. I changed the plugs and put iridiums in and also changed the fuel filter. And gave it a service. I only got the factory boost gauge and was unsure of what it was running before but it used to stop at 7 but now after turning it down 4 notches it is on bout 6. Much much slower on boost now. Not happy with it and want to know if there is anyway to get around this boost cut situation without getting a front mount?
https://www.sau.com.au/forums/topic/22734-boost-problem/
sounds like a good tip..... only with mine the problem has been cured by removing the cheap and nasty mechanical boost controller.....all I need to do now is work on restoring the kick ass power I was used to. From what I have learned recently a good electronic boost controller is the way to go.
Cheers
Chris
https://www.sau.com.au/forums/topic/22734-boost-problem/#findComment-490350
OK - if your getting a reading of 6-7 on the factory boost gauge that means your running about 13-14psi !! (7 on the factory gauge is close to 1 bar).
It will be the factory boost limit or your plugs. Regapping your plugs to 0.8mm might help.
I wouldn't recomend that you run more than 10psi if it's a series 2, and 12psi if it's a series 1.
J
https://www.sau.com.au/forums/topic/22734-boost-problem/#findComment-490381
yep, it's a series one.....I have an auto meter boost gague, with the origional disconnected. As mentioned above the car now runs smooth, I just need a reliable and controlable way of reaching the 10.5 psi it now reaches through a restricter. I don't think it needs to boost any higher than that.....just want to get there a bit quicker!!
Ta
https://www.sau.com.au/forums/topic/22734-boost-problem/#findComment-490393
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 馃槑
    • Cool, I鈥檓 just down Sydney today. Not much time to get online.
