Rb26 Rb30 Big Hp Parts For Sale....
Hi
i have a shitload of aftermarket parts for sale i was going to go hektik in my s15 with a rb30/26, and no have deciede im going to buy a house, doing the smart thing
all the engine parts are brand new and some of the bolt on parts are second hand but pretty much brand new.....
i am slightly negotiable on somethings so don't bother with low offers, i simply wont reply....
everything is in Sydney, i have no pics atm but will in the next few days......
most parts are for a rb26
Hypertune intake plenum with 85mm (internal size) throttle body, no fuel rail.......... $ 2300
aeris pistons, on spool rods, assembled, but never used...... $$ 1300
Jun oil pump, only fitted to engine, never used.... $ 1000
RD 28 nissan patrol deisel block,virgin bore, shits all over rb30 blocks, and has piston oil squiters $ 800
rb26 cylinder head, complete minus bolt-on hardware like cas and ignitersd and stuff like that, comes with buckets, valves, shims, caps and rocker covers, has had a hardness test, came back perfect, $ 1200
ACL race bearings, installed then pulled out, never been used $$ 300 for the lot
GTR head studs $ 200
main studs $ 150
stainless steel manifold for rb26 $$ 350
Innovative turbo systems GT80 turbo, rated at 1050 hp at the wheels on a 3l, 80mm front wheel, .96 rear housing with a x trim wheel, silicon nitride bearings, BRAND new $ 3600
Motec m8 ecu has all featuires unlocked like dual band lambaua and also data logging, comes with wiring harness and map sensor
hks cams 272 10.2mm lift inlet and exhaust $ 800
hks valvesprings to suite above $ 400
rb25 gearbox perfect conditioon $ 1100
ati harmonic balancer 1000hp version with water pump pully $$ 800
s15 rear cross member with all r32 gtr acessories, diff, arms, hubs, brakes, everything.... $1500
thats about all for the time bieng, if there is more that crosses my mind ill post it in...
cheers
denis
Edited by den001
there is a fair bit of modification to get the head to bolt on, the head bolts are in teh same position, there is a water jacket at the rear of cyl 6 that needs to be welded up and the 3 front oil return lines from he head need to be modified with external lines for drainage, you use teh rb30 crank and these blocks were used to running abour 24:1 comp ratio, they weigh about 40ikgs heavier than a conventional rb30 block, and all that weight is situated in the cylinder bores, so it makes it a optimum block for shitting on 2jz blocks,
This very interesting, who got you onto using these blocks i say it would be a much better choice then a 30 block even tho you have to mod the water/oil galleries would you know how thick the wall are because if they are pretty thick would be a good idea to bore them out pretty big like to say 92-94mm and make it a 3.4L
So all the mains fit the 30 block
  • 4 months later...
Hi,
I built a RB25/30 with a solid lifter conversion. I intend to replace the RB25DET rocker/plug/camgear covers with RB26DET items. I already have the rocker covers but I still need the sparkplug cover (that goes between the rocker covers in the middle), the front cam gear cover (with the RB26 logo) & also the backing plate that sit between the cam gears and the head.
If you can help, give me a yell at [email protected]
Kind regards
What I did with my RB25/30 was overbore the cylinders and sleeves pressed in, then torque-plate hone the cylinders and also o-ring both the block and head faces. That shits all over the 2JZ in terms of strength as well.
My engine builder recommanded sleeving because it turns out way stronger than using the N1 or the GT blocks, it also gives me the option of punchin them out and installing sleeves with a different bore size if the need arises.
Match that to the forged components on the bottom end along with the extrude honing performed to the head and inlet manifold, this is one invincible donk.
  • 1 year later...
Hi
aeris pistons, on spool rods, assembled, but never used...... $ 1300
ACL race bearings, installed then pulled out, never been used $ 300 for the lot
main studs $ 150
stainless steel manifold for rb26 $ 350
ati harmonic balancer 1000hp version with water pump pully $ 800
cheers
denis
Hi ther just wondering if you still have the block for sale??? Cheers
 Share
    • So I've been working on the car a fair bit, doing a lot of little things. Preparing some projects for this winter, as I'm taking 13 weeks off very soon for parental leave. Have my second kid on the way and he's due any week now. I'll need something to do while he's sleeping. I also usually take the car off the road in about a month and a half, until sometime around the end of March.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
    • Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not  on the street
    • i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
    • Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
