not to sound dumb or any thing but what breathers and acc feed ??
yer ive wanted to do this for ages now i just for it and it turned out good very thin stuff to weld thou need patience
oil breathers, the back pipe that goes from the fitting on the plenum to the black fittings that are on the top of the engine, on the cam covers, then to the intake.
aac valve feed. the 20-25mm pipe at the back of the engine that usually goes on a fitting just before the throttle body on the stock pipe. without this your cars idle wont be stable.
im talkin about the ic piping from tge plenum and im gonna have to weld something at the back for that black hose to attach to and for the other breathers im making a catch can to go where my battery is as my battery is moving to the boot
i'll put up picks in the next week or so of the 2 rb20's ive done ic piping one.. im in the process of doin fmic piping on a rb20 silvia at the moment.. after thats done i'll try get pics up
im not actually a fan of that style of ic piping with the factory manifolds but looks ok.. be sure to put up pics once you've finished.
sounds good, just not much detail in your first post :thumbsup:
what material did you use thats so thin? most alloy tubing i see is pretty thick
it was 1.6mm half of it is the stock pipe and i bought a 180 DEGREE bend it was hard to weld because it was a buut joint and you need the rightn pulse and frequincy along with the correct amps of course
cool man will be good to see some stuff youve put together,yer i cant afford a forward facing plenum yet so i just wanted to take off the stock pipe that crosses the block
shit yer ,man that looks nice are you a fabricator of some sort or is this just week end work either way very nice work
thanks not quailited just done alot and lot of work with in the metal industry as a labourer.. did start doin an apprentiship as a boily however i have umm how do you say it.. problems with authority lol
the piping jobs i do are more of a hobby and to help people out who have been quoted stupid bullshit prices for the work.. would probaly look at it more as a business adventure however theres just not enough work for it up here and not many people want to pay for a top job.. they'd rather spend 3/4 the price for a cheap shitty chinese supposely "bolt on" kit..
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
