does a wake feild licence pass it has the cams symbol on it
You might be better checking with the officials in the NSW thread. My thoughts on the matter: Wakefield is AASA (so isn't CAMS) however my understanding is that if you have a Wakefield Licence, that is now considered as AASA Licence as well and is therefore quite okay for Texi - but don't take my word for it, check with Wakie and make sure your licence is AASA and valid for other AASA recognised events and then verify with Texi officials that they accept AASA.
  • Replies 41
ok cool thanks mate
Guys, if you're thinking about entering please do it ASAP.... if we don't get enough entrants there's a chance we may have to cancel this..
we'll take CAMS L2S or L2NS, or AASA licence
not sure what your one is - wakefield should be AASA not CAMS as far as I know??
Shell I've just got the 30 day license from SDMA (waiting on CAMS to send em the full license) Is this OK?
Texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi, texi
YES!!! :laugh:
Edited by DriftGTS
YES!!! :D
excited much? :laugh::bunny:
Anyone else entering? Texi is now in doubt :P sucks :P , any sdma people interested michelle?
I'm guessing you really meant the one L Shell or otherwise you will confuse 2 L Shell LOL
I'd like to go, but its on the same day as round 6 of the NSW State Hillclimb Championship :P
we were told we would be permitted NO LOSS OF TRACTION whatsoever on the big pan (VMA)... we explained that we would not be sitting there doing static burnouts or anything like that, but they were very clear.
So we had little choice but to use the wet pan instead. Our first one ever (last year) was run with the wet pan and everyone had fun, so we hoped ppl would still be keen to come..
I'm easily confused :P
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
