Don't think it will remove the boost cut - because I think they don't have one.
thanks for the reply
installing my front mount upped boost to 10psi, after puting in a boost tee i had fuel cut with any increase above 10psi thought that might have been ecu over boost protection, but maybe its something else.
maybe aftermarket ecu is my only choice.
thanks again :(
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004463
I would pm CEF11E or drdrift. CEF11E is in Melbourne but he does do r32 remaps, and your 32 ecu would need a cradle put in etc. He does do tunes without dyno time as well. Think he was charging around 150$
i have a pre programmed eprom by some company called marobi, only cost $15
wasnt going to put it in but maybe it can solve my problems.
think its a bit dodge though as not tuned on my car
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004646
Have a chat to cef11e or drdrift, if your not happy with your current remap, as they both have a fair bit of experience, I have one in my car, any only reason I need to change it is due to having a boost leak when the car was dynoed. Ceff11e has done countless r32 remaps now.
https://www.sau.com.au/forums/topic/227482-r32gts4-remap/#findComment-4004663
    • Ha ha, that is very true!  I'm too scared to leave it in the position though, it tingles my balls seeing it like that!
    • Which one did you buy? I have always wanted a decent inspection camera but have been unable to tell whether something is cheap junk or cheap junk chunk sold at just a bigger markup
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
