Attached are two pictures, I am trying to identify what the electronic gismos are that are attached to the right hand side of the tranny tunnel (ie above where driver's left knee would be) and above the steering column.
thanks in advance
Also if anyone knows what the screen is and the bit in the guys hand which I understand to connect to the screen, I beleive it is pioneer carrozzeria gear, GPS/TV etc, can this be made to work in Australia?
cheers
It has tein suspension, but no black box...
Do you know what intake pods these are:
and why is the paint on the intake plennum all flaked like that???
Do they look like the standard size AFM's??
Shit I cannot wait for this bloody car to arrive:
Edited by R34kid
Yep, it has Apexi oil temp, boost and water temp.
and QWK32 wins the freddo:
http://images.google.com.au/imgres?imgurl=...%3Doff%26sa%3DN
Marlin, already bought and on its way here from Japan
Edited by R34kid
thanks in advance
cheers
nav,TV are useless. I ripped that EXACT setup of of a S15 varietta 20 minutes ago.
The air pods look like M's Airpods, keep them as I was told they are rare now or discontinued.
Looks like you got a MP3 and DVD Player,
It seems you have a HKS Turbo Timer,
3 x APexi gauges with the gauge controller,
The TV will not work in AUS unless you get it converted to AUS Frequency as it is to display the GPS.
The gadget on you steering wheel on the bottom left, looks like it is to control you sound system (remote control). Could be cruse control but I doubt it.
Air Flow Metre look pretty standard,
Inlet Plenum is all flaked like that is because over the years of heat from the engine and in some cases the car has been driven hard and the paint flakes off again due to heat.
Ok thanks,
so the nav and the tv are useless? that sucks, getting it converted to AUS frequency will not make the GPS work though will it but I can still play dvds through it?
As for the inlet plenum flaking, this car is supposedly a genuine one owner 58,135 kilometre vehicle with log books and service records. So it should not be flaking from prolonged exposure to normal heat which means it is likely to be from hard driving generating more than normal heat. Shit I hope the motor is not shagged from being driven hard, that will suck ass if I need to rebuilt the bastard!
really. do you have hte firmware to do this? unit is jap based and the DVD side of it is locked to another region so its useless as well unless you wish to burn DVD to open region.
in regard to the plenum - last 260 RS I did had 90k on it and it looked the same. think about how much heat is under there..
Ok thanks,
correct. nope unless you wish to do as I already stated. its easier to rip the lot out and start again. the radio you can save. chuck a $30 band expander on it and use it. if you are in brisbane I keep these.
No I am in Perth WA. So to have the firmware reflashed (?) will that then make the GPS work?? surely that will be cheaper than throwing it all way and buying new stuff, otherwise I will just have it all removed and go without, not like I get lost anyway ahah but the tv would be cool! I can easily burn DVD's to open up the region so maybe just keep it for that. Do these things receive television also>?
just rip it out...
much easier. pioneer Oz wont touch it anyway. they did do TV and some of them supported a hardwired carkit as well.
its NOT useable leave it at that.
