Need Info On Stagea
Ok so my car is at the compliancers now so i took the chance to go have a look at since there wasn't any photo's of it taken in japan my main question is the dash inserts and doorhandle inserts all of them are carbon fibre i wanna know if this is a dayz factory option that came with a dayz kitted car or are they aftermarket the car now has a 260rs kit on it just wanna know if origanally it was a dayz edition kitted car? Any info would be very helpful
Looks like c/f rice........nice all the same. Get the vin # fasted in the relevant forum section. Tha'll tell what your baby was birthed as from factory.
Cheers GW
Edited by 260tech
Cheers GW
cf rice?
it's a factory DAYZ option. nice stuff :whistling:
*edit* bah, uploaded the wrong pic and now i can't get rid of it/change it... oh wells
Edited by M I K E
spotted what looks to be a rear tweeter in the rear door in the last photo.. never seen one there before. its good to get all these extra little bits in your car :whistling:
spotted what looks to be a rear tweeter in the rear door in the last photo.. never seen one there before. its good to get all these extra little bits in your car :)
Yes lots of suprises with this car also got this it's an M's booost controller apperantly thats all the info i could find on google NFI how it works tho :whistling:
spotted what looks to be a rear tweeter in the rear door in the last photo.. never seen one there before. its good to get all these extra little bits in your car :O
mine looks to have the same from photos i got, cant wait to rip the things out i think they look ridiculous!
Yes lots of suprises with this car also got this it's an M's booost controller apperantly thats all the info i could find on google NFI how it works tho :O
Does anyone have any idea where i can get info for this thing if i can get instructions for it i'll keep it if not it'll get ripped out
Those Carbon Fibre bits are an optional Carbon kit that could be ordered with the Dayz. I would say that it might be genuine Dayz accessory, but they are also available aftermarket. I have those tweeters on the front door. They work ok, but a bit of a pain.
Cheers :D
This appears to be the manufacturer have you tried contacting them?
http://gizzmousa.com/boost-controller.html
these instructions are for a different model but they may help you or you might be able to get the right ones by asking above
http://gizzmousa.com/file-copies/Gizzmo-MS-IBC.pdf
No thats not it those are gizzmo which are aussie made, This one is a brand made in partnership by M's and Akimoto and the only info i can find on it is other people asking how the hell they work.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
