Anyone drive on Fitzgerald St. North Perth?
New speed bumps there now and it is farkd up, MASSIVE AS, so any cars with bodykits or are low, watch out for that street.
and its not only just one there, its like 3 or 4 in a row.
pretty fcked up
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/
pretty fcked up
Sweety they've been there for ages!!! I didn't see them either and I used to drive a lowered cresta and smashed all my front lip in on them back in my january! :whistling: Horrible stuff hey!
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4004900
pretty fcked up
That is why I head north and hook back up on the freeway...
God damn stationary policemen!
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4005977
Oh and those ones they have around applecross now that are just bits of metal dynabolted to the road. those are harsh as, and they are on all my favourite streets.
Sounds like oxy tourchy time!!!
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4008671
hey viet_boi,
i like your avartar, do you know her name by chance. She is hot as.
Cute face as well. Well done, yeah i drove on that street like 3 times already and drive like 2kms, heheeh
bye
pretty fcked up
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4008759
hey viet_boi,
bye
thanks for that...had so many PM's asking for her name and shit...horny people..haha
My Avatar..is FTW
Edited by viet_boi
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4008779
Btw with the Speed bumps on Fitzgerald St, we did a little testing last night and figured out (as long as there's no one in the other lane) That if you drive in the middle of the road and go over them, feels like a normal speed bump! It's cos they're so boxy and aren't bloody wide enough!
https://www.sau.com.au/forums/topic/227504-new-speed-bumps/#findComment-4009186
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
