Hey guys, i just got my exhaust for my car, a 3" turbo back Xforce sstem for my R33 GTST... its supposed to be a direct bolt on.... i phoned a couple exhaust places one quote $160 and another guy said he cant give me aquote because alot of the time they arnt direct bolt ons nd things dont line up so he gve me an hrly rate 70 bux/hr (which makes me kindah iffy)....
i was thinking of having a crck at it myslf... how hard can it be?? Any one with ny experience on this have ny advice/tips/info on what i need to do??? Are there any tutorials?
also anyone have any experience with the xforce system? Does it bolt right in??
https://www.sau.com.au/forums/topic/227509-exhaust-installation/
x force systems fit up nicely! my friends shop does them all the time and not had any problems!
you should be able to get it done in a few hours.
if you dont mind me asking how much did you pay for the system and is it stainless or mild? pm me if you like
cheers :whistling:
The only problem you most likely will encounter is having extremely tight nuts and studs on the turbo.... Easy solution, buy a can of wd40, spray all the nuts and leave it for 30min, spray agin and leave for 30 min. That should free them up nicely....
Putting the down pipe on is the hardest part, as its the hardest to get to, but its still quite easy... Take your time, and you'll enjoy the reward of doing it yourself.
Hey guys thanx for the replies, i think ill have a crack at it later today or tomorrow lol...
i emailed x-force to ask the recommended retail price and they told me 950 for the mild steel system... so when i shopped around croydon racing developments quoted me 1250 for system and installation, and i found the system elsewhere online 799 for the mild steel.... and with continued searching one came up on ebay a guy in sydney that sells exhaust systems... $680 bux it cost me... i picked it up to save on shipping, if anyone wants the sellers name lemme know nd ill find his ebay details.
So last question... when i join the sections up should i be sealing them?? with exhaust cement/gasket goo?? Or is it fine to just bolt everything together?
You can use exhaust cement for peace of mind.
As nuclear said the dump pipe off the turbo will be the hardest part.
I pulled one off yesterday and the bolts were 1/2".
Plenty of WD40 and patience helps.
Edited by bluey33
Ok... whos idea was it to install this thing on my own?!?!?!?!!? lol just kidding.... its not exactly hard.... just a pain in the ASS....
so i went to supercheap... bought 2 ramps and some exhaust sealer... (it was about 2:30 pm when i started lol) pulled out the cat and pipes all the way to the rear... and managed 2 install everything from the cat back... 2 problems... the *@^@#^* silencer wouldnt come out of the freakin muffler... took us like an hour to get the retarded thing out had to push a big chunk of wood through the other end and hammer the shit out of it till it poped out...
second problem... the sensor wont go back into the cat!!! It pops in but not far enough that i can screw it in... i think when they made the holes they left a small amount of metal at the base which stops it goin all the way through... gunna try to drill it out tomorrow... any other ideas???
i ran out of daylight... will tackle front pipe and the cat sensor tomorrow... the rest went together alright...
Yeah your right, the temp sensor for the cat doesn't fit. You've just got to drill out the hole so it accepts it, no biggie really....unless you don't have a drill and drill bits.
Weird that the silencer got stuck.
All I can say is that the dump/front pipe is the hardest to fit. Getting to the nuts around the turbo is the hardest but not impossible. Take the heat shield off the turbo to get to the ones around the top.
Here's mine back in the day
http://www.skylinesaustralia.com/forums/Xf...st-t144283.html
ok so anyone that's thinking of installing your own turbo back exhaust that doesnt really know what they're in for: DONT DO IT....
cat back fine go ahead and knock yourself out... but that dump pipe is a **** to get off. I nearly gave up... not worth the hassle... oh and i didnt have a drill that can widen a hole in stainless steel cat... i dont think many people would lol... yeah the guys at the chop shop had to do that for me... even they didnt know if they could lol... he sharpened his drill bit on a grinder and we got lucky.
As for the dump... chewed through my socket wrench adapter, and 2 13mm heads and 1 of the neighbours set lol i was scared we were gunna snap the bolts or thred them... had to call in reinforcements, a friends brother in law that had a massive socket wrench... the plate that holds the heat shield up was a bastard to get around i dunno how we did it to be honest... just wd40 the shit out of everything nd pray for the best...
And then theres the silencer that thought it was welded inside the muffler tip... i showed it... had to jam a large bit of wood through the other end of the muffler and hammer the shit out of it... it took forever to get out...
apart from those three things and an almost dislocated shoulder and stiff neck, 2 half days of work, and working by moonlight, everything else went peachy :)
but seriously... dont do it... bewareeeee.. BEWAREEEEEE
my neck hurts :D
Wow, i can't believe you had so much drama.
And as for the guys at the workshop that weren't sure whether they could drill stainless.......what the heck??? what kind of workshop was that? I did it with a standard high speed steel drill bit and a half dead battery on the cordless.
Are you happy with the results of the performance increase? If yes then that sir is the joy of modifying. Do it yourself and you'll enjoy the results more. Not to mention you learn a lot about your car, so if something goes wrong you have a pretty good idea whats gone wrong because you know your car better than anyone else.
Nonetheless, the general rule you should folllow is, if you haven't done it before and your going to do it yourself, excpect it to take twice as long, allow for the unexpected.
Also depends on your mechanical competancy as well too I suppose.
Also, get yourself some good tools, there's nothing worse than using cheap crap that breaks on you. I've done it before and got the job done with cheap tools, but they only last for that one job and half of another. After that its shot.
I and many others haven't had as much drama as you have, but every car if different so I can sympathise for your troubles.
Happy modding :bunny:
lol it was cool to learn seein how i had no idea.... but i think the sense of relief, outweighed the sense of achievement after it was done...
Performance increase yes... she idles smoother and does everything smoother coming on acceleration, even accelerates noticeably quicker... but loud as hell... we went to an enclosed car park to test it nd i did a drive by past a friend under 60km/hr nd he said he could feel the ground shaking not to mention the enourmous roar defening everyone in a 5km radius... lol... ok so slight exageration but u get the idea :bunny:
and yes i need better tools lol... the $20 ratchet set from supercheap wont cut it lol!
yeah i can't beleive you had that much trouble either man...god knows, i'm not the most competant when it comes to mechanics either...but it sure didn't take us that long...the time it took you to install ur system was about as long as it took for me to do my intercooler on my own...but oh well, you got it done, that's the main thing :)
The Bolt on the back of the turbo are 1/2" not 13mm which probly explains why it was such a prick to get off and also why you chewed out the sockets.
Just Nit Picking Here :)
Oh glad its finally on! and the price was pretty good, i do have access to these exhaust's and would probably sell for around the same price. and around 250 more for stainless..
as for the install, good its finally on! but a hoist is defiantly the way to go with any exhaust, and a good set of tools is always good too!
Performance increase yes... she idles smoother and does everything smoother coming on acceleration, even accelerates noticeably quicker... but loud as hell... we went to an enclosed car park to test it nd i did a drive by past a friend under 60km/hr nd he said he could feel the ground shaking not to mention the enourmous roar defening everyone in a 5km radius... lol... ok so slight exageration but u get the idea :D
Watch out for that excessive noise!
I recently had a full system fitted by CRD and the bastard is as loud as your description.
Idle is acceptable, but try even gentle acceleration on the road and the thing spits, rumbles, and roars. Pedestrians and cars within fifty meters of me turn to see what all the commotion is, and every friggin' boy racer (and non-boy racers who suddenly become converted) wanna race the gruesome beastie rumbling away at the lights next to them.
Shit. Even babys in prams are checking me out...
I think I just disabled sleeper mode...
Thankfully, the exhaust came with a silencer (kind of like a funnel) which you just bolt in the rear to restrict some of the airflow, and therefore reduce most of the noise. Works like a charm, and you only lose a few kW. You should see if you can locate something similar, or you may even wish to consider a Varex Muffler.
Edited by coakman
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.   Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
    • Hmmm.... It's actually a bit weird. Here's the key bit of the diagram. I've circled what I'm pretty sure is the high beam indicator on the cluster. It appears to be just in parallel with one of the high beam lamp globes. Meaning, that however the high beams get lit, the indicator should also be lit. So there shouldn't be any difference between being on normal headlight main beam, or just flashing. I've followed the physical diagram (which is not so easily summarised in a single snip, so I didn't put it up here) and it agrees with what you can see here. If you struggle to follow this crap....let me explain some of it. I always struggle when I first look at this - even though I have looked specifically at this more than once in the past. We'll start with the flash. The flash is triggered by pulling the dip switch back, right? That is indicated on the diagram by the P position on the switch block labelled "Light SW", on the RHS of the snip. The bottom-right most terminal is connected to ground. That's that wire line going down to the bottom. The next terminal up is connected to the bottom terminal when the switch is pulled back. That provides ground to wire LA33, which is connected to the coil of the relay in the middle of the snip, "Headlamp relay (2M)". That relay always has power on the other side of the coil, from fuse #19 above it. When that relay is triggered, the two main headlamp fuses #32 & #33 above feed through the relay down onto wires LA31 and LA32, which are connected into the wires that go to the main beams, LA04 and LA06. The cluster indicator is connected to LA32 also. When the main beams are on normally, the light switch ("Light SW" again) is in the M position. Power comes in for the left and right sides on LA34 and LA36, via the other light switch (the one on the binnacle, called "Light SW (Instrument)" on the diagram). Obviously that switch needs to be in the 2nd position, because that's headlights. 1st position is parkers. The same main headlamp fuses #32 & #33 feed through that switch, out via LA34&36 to the stalk switch, and of out of the stalk switch via LA04 and LA06 to the headlamps. From there, it is no different to the flasher version. I really don't know why they bothered with the flash relay. They probably didn't want to add another contact in the stalk switch - but I'm damn sure that's what I would have done. Just reverse the order of power feed, so that it goes from the fuses to the stalk switch first, and add another contact for flashing. Everything would have worked just the same, but less complicated. /bitchrant
    • I think the solution Pac posted in the other thread is the way to go with the top screen; I have an ADM Q50 and I only use it for 2 things: 1. Reverse or front camera as triggered automatically by Reverse selection or the front sonars, and you can also call up the front left (or front) camera when parking by hitting the camera button on the centre console if necessary 2. Navigation. I can assure you that getting hold of a 10 year old nav system is utterly useless. The ADM system still has Inifiniti dealers marked (always give me a good laugh), is missing all new freeways, uses fixed speed by road type to determine arrival time, no traffic/re-routing, no speed cameras, no user reported cameras etc etc you get the idea So, Pac posted in the other thread about a box that plugs into the USB C and gives you full Android OS to run whatever modern/connected nav you want on the top screen, and it still automatically switches back to function 1 above when required because it runs within the head unit. The other modern alternative is the latest version of the Tesla screen like this:  https://www.aliexpress.com/item/1005007511322502.html?spm=a2g0o.productlist.main.25.33cefEZifEZibq&algo_pvid=cdae429c-aa8d-437f-a436-c727fee85461&algo_exp_id=cdae429c-aa8d-437f-a436-c727fee85461-12&pdp_npi=4%40dis!AUD!2181.36!1265.19!!!9834.81!5704.20!%402101c71a17362022663526105e36d7!12000041077843545!sea!AU!163137612!X&curPageLogUid=F9811g8oqx5H&utparam-url=scene%3Asearch|query_from%3A But I haven't looked into whether it is compatible with Australian 4G bands yet so it may require a separate 4g dongle to provide data
    • In the 32 race car, I basically run what Gary told me and it is lovely across a range of conditions which is what I needed. I've got revalved bilsteins, adjustable solid sway bars, adjustable bushes all round. Just looking at Neil's R33 GTST and it has pretty much the same on board, Gary Bilsteins, Selby/whiteline sway bars.  Gary knows suspension generally and these cars specifically very well across street, street/track and track only use and gives a very well balanced set up. Just be aware his preference is for light springs and heavy sway bars, there is another school of though (eg MCA) that prefer lighter swaybars and heavier springs/shocks. The evo I raced had that setup and it was also very nice so there are multiple ways to skin cats.
