Hey guys,
my 32 gts-t is idling at around 1,500rpm, and it feels the tps could possibly be a cause. It feels a little out, when switching from light throttle to no throttle at low speeds, kicks and jerks around alot.
Has anyone else experienced this? I've had a look around but can't find anything clear on how to adjust these.
What RPM is normal for idle on a rb20?
cheers guys :whistling:
normal idle is around 900rpm or less even 800rpm (its on a sticker on the underside of the bonnet)
if TPS is dead RPM will jump and peg at 1500rpm as a failsafe for the engine
so if you see your idle ramp to 1500rpm and sit there, the TPS is toast, that is, the value its telling the ECU is out of range, ie: its probably 0.0 when it happens.
if the TPS is toast the car will be jerky as cos the computer will try and detect and determine load from the TPS, but the sensor goes to 0.0 (lets say) so it jerks and is stally
i have the same problem at the moment, no idea whats causing it.
Probably what that guy said.
That's shit news but a mad bit of advice man, cheers!
Do you know roughly off the top of your head how much a new TPS is?
Edited by G Kanobi
they arnt that much at all, could probably find 1 for $50 or something, me and my mates did a engine conversion on a laurel putting a rb20det into it, when we hooked it all up and started it it ran like crap, miss firing and everything, trying to pull all the plugs off and re do it, we found out it was the afm that was unplugged, so we started it again and it went straight to 1500rpm and still just wasnt running right which was pissing me off even more, found out my mate didnt plug the tps back in properly ands the idle dropped down to 1000rpm, so i think tps is the right track, at least its not hard to change,
gl with it,
how about knocking 100revs or so off the idle?
i tried the screw in the front of the ecu, but it did squat.
mine sits at about 1000/950 which i find a bit annoying :|
Edited by norwest_rumbler
if it sits dead on 1500rpm, the tps is bugger as mentioned above. If there is anthing wrong with the tps the ecu will go into a safe mode and just idle at 1500rpm. Check your voltages at the tps at fully closed and open, and if they seem correct adjust the idle screw on the throttle body.
Edited by R34GTFOUR
The grubscrew on the idle stepper.
where is the idle stepper located? i have a r32 silvertop.
is it the round thing about the size of a D size battery with wires coming out of it thats mounted on the top rear of the intake manifold?
or is it the thing that looks like a diaphragm with hoses coming out of it below the throttle body? (doubt it)
either way i cant find any adjusting screw
:D
AAC on a RB20DET is located on the firewall side of the i.plenum, it's rather D size I guess'ish hah.
Nissan say 600rpm.
thanks a heap :) i never would have found it without that info.
it was seized up, but a bit of wd40 fixed it. i set the idle to 600, even had it ticking over at about 400 no probs.
cheers
you can see the screw from the drivers side of the engine bay.
all you need is a flat blade screwdriver to turn the screw, clockwise (winding it in) will reduce the idle speed.
best to adjust it when the car is at operating temp
cheers
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
