Hello guys,
i read a lot of "oppinions" about the "crank-collar-case" until now however i'm not sure about a few things.
I have a JUN oil pump and do i need to fit a crank collar on my RB25DET '95 (Series 1.5) engine or will the RB25DET
crank match the JUN Oil Pump perfectly ?.
As i heard only the "most" R32 GT-R RB's have problems, but didn't heared anything about the RB25DET ??.
The next thing, if i'm understanding right that the collar have bigger flats to run the oil pump, do you mean wider flats, or longer flats, or both ?
Thanks in advance for your help guys.
is that all rb25's? or just ealry model ones?
short answer: you will need a crank collar
longer answer: all rb30, rb25, and early model r32 rb26 cranks are narrow and need the collar, the later model r32gtrs, r33gtrs and r34gtrs have a wider "snout" and dont require the collar to fit a pump like the jun
Edited by R34GTFOUR
OK guys can you please help me to understand this, some are speaking that the flat surface isn't that wide as it should be.
Do you mean the width of the flat surface or the length of the flat surface or both?.
I need to know this to be able to explain it to my engine builder.
Check this:
Check this:
length...your engine builder doesn't know this??
send it to me.
If he didnt already know, cant be that experienced with RB's... make me wonder about other things like oil control etc
Sounds risky to me :D
yeah RB's are a bit more involved than a Holden Red motor.
Edited by DiRTgarage
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
