hi guys
I have a R32 gts-t and had the engine reco'd about 2months ago to standard spec. I made a big mistake not putting in forged pistons in. my question is which might sound abit dumb :P
is it possible to change the piston's with out taking off the head again and pulling out the motor? e.g., like put the car on a hoist and taking off the gearbox, oil pan and oil pump. And unblot the crank and pulling out the pistons.?
cheers
bill
https://www.sau.com.au/forums/topic/227563-changing-pistons/
nah mate head has to come off. cant drop them out the bottom. generally u have to take motor out again put on a stand take head off take sump off and one by one unbolt bigends and slide pistons and conrods out the top. a fair ole job to wanna go and do now. basically strip it back to a bare motor pretty much. if u got bucket loads of money go nuts.
Edited by skylinekid
No problems just cost time and money for labour, new gaskets, sealant etc, but you will need to hone the bores to suit the forged pistons to get piston to bore clearance right and bed in rings as far as I know.
hi guys
cheers
bill
Hi there, apart from cast pistons, what kinda big mistake? Effective life of motor after big mistake? Like can yurun with a de-rated motor for the intended purpose for a while (like 40k's) or is the intended purpose gunna foobar it? If the latter is the case then pull motor out, strip it down & fit gear that will achieve yor purpose. Most cost effective option.
Cheers GW
my car is already pushing 232rwkw's and i dont think it will last to long. i know that u have to put the pistons through the top. but i cbf pulling everything out again. i dont see the difference would be if u go through the bottom?
cheers
bill
Your probably better off sourcing another bottom end, then building that up in the mean time.
At least that way your not without the car for weeks on end while you take it all out. Could probably just sell your bottom end on them to re-coupe costs. If its making that power now and the tune is good there is no reason why it shouldn't last.
Cheers.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
