Hi Guys,
Okay, i drove my car for 30minutes and went to fill up at the servo. When i got there i popped the hood to check the oil level as i do every week.
Tonight i was shocked to see the oil level was waaay beyond full! about 1/4 of the way up the dipstick! So i wiped it clean and stuck it in again(with the engine still running).
The result was the same...
Why would this be happening? I am starting to stress that this could be a more serious problem but i dont want to take it to the mechanic and ask before i get some advice on here since im afraid they will try to tell me its worse than what it actually is.
Any help is appreciated. Thanks.
https://www.sau.com.au/forums/topic/227579-is-this-something-to-worry-about/
Hey sean,
I just checked it then with the engine off, and the oil level is beautiful not too high not too low :P
Don't understand about the oil sloshing around while i drive? how would i tell?
Oil pressure and temp gauge's are within the normal ranges.
Is this all normal?
Thanks again.
Hey sean,
Is this all normal?
Thanks again.
As long as you ain't taking the mickey, here's why.
The internals are rotating at a thousand revs at idle. The crank, rods, pistons are throwing off oil that has lubricated them as well as oil draining from the head oil returns. This all ends up back down in the sump along with frothy aerated oil from the turbos. The oil level will not be true as it will be mixed with air and sloshed around in the bottom too. It may bubble into the dipstick tube and run up the dipstick to give a false reading.
Cheers.
wtf is ur problem?
i am new to this scene and i am overcautious about my GTR.
My old car never used to do this even after it was hot, so that is why i was wondering.
I didn't realize that asking a f@*&^ing question was cause for being a smart arse...
As for GTRsean, thanks thats what i thought, but just wanted confirmation that nothing was wrong internally.
Edited by GTR-PWR
Lol Deren, PS i meant to be checked like that.
Hey, I understand where Harry is coming from, when I tell some mechanics I work in IT, drop off the car dressed in a suit and tie, clean all the grease and other shit off me, and go off for a meeting with clients, they sometimes talk to me like I am blone, 18 yrs old, and never lifted the bonnet on a car before.
A lot of people dont actually know their cars as well as others do, but they still love them as much.
Remember people, we all started in this scene somewhere, for me it was when I was 10, and saw what Nissan's godzilla could do at Bathurst, from there I knew the potential of cars with build quality.
For others it's when they decide to bite the bullet and give things a try, and get a Godzilla to see what the hype is for, at least Harry is trying to keep an eye on the car, and care for it.
B.
Thanks Brian, well said mate.
My strong passion/obsession with my car is one which cant be easily described and i am at trying to do everything i can to learn more about it mechanically and how to treat it properly.
We all need to start somewhere, keep in mind 3 months ago i was driving a VP Executive AUTO and had driven a manual car maybe two times before in my entire life.
I am also very passionate about my GTR. Only gotta read my GTR thread to understand that! Im very fussy and very pedantic. If you or anyone else ever needs any help with your car (especially GTR's) please do not hesitate to contact me, as a mechanic i am more than happy to help where i can.
Good move with the VP :) Buying a GTR was always my dream too.
    • it takes so long to get things done but ... they are nearly there and we hitting the track soon again  So - at Perth Festival of Speed the car unfortunately had a decent off, wasnt me driving, wasnt the person drivings fault. Long story short car got sent very fast towards the wall without the control on throttle from the driver input and a disaster was averted but there was damage that needed to be fixed - carbon busted and alot of bent bits The splitter got munched and had to go back to get fixed - took a bit to get it there, fixed and back but got a surprise package when a new double element higher DF splitter came back - nice surprise !  and first person to have one     At a car show I took the car too some punks stole one of my carbon indicator blanks and stomped on the other so had to get a new set of headlight / indicator combo from tops stage so got front fender vents as well to put in the order     While all this was happening the new MCA golds turned up and did some fiddling around with those   Put in the flappy paddle system and clutch lockout wiring/ system   We have also put shorter gearing in top top it out at 300 kmph in 6th gear  where previously I held 5th to 282 at SMP and 277 in Perth   Looking for better control and faster acceleration     I wasnt intending on doing pedal box I was managing with the brake master replacement system I had going on and adjusted std pedals but on applying the clutch switch to the old system we found the *insert technical word here * bar that goes from the pedal to the master was bent about 40 deg and about to snap = lucky find otherwise be a bad bad time - discussion was had about getting a custom bar built to withstand the load but in reality it was time      making any suspension, wheel or anything adjustments to date has been a nightmare - aero off, adjust, check and repeat - time consuming and hard - short of going full airjack system we fashioned some external manual car lifts this will make life a million times easier     All the bent framing, some intercooler pipes and other has been fixed and replaced and after 6 months I finally have the car back at home in my control so its get to work on it, set ride heights, wheel align and will start track testing again soon   So ultimately other than a few flashy bits nothing actually looks likes its been done but in reality alot has. Typical   We'll see how all this goes
    • I'm far from an expert, but for sticking bits of metal together occasionally I got a MIG, the biggest one I could get with a 10a plug (because while I have some 15a GPOs around, they are not everywhere).  Also, because I get through SFA, I just buy the small disposable gas bottles at Bunnings, I'm not opening a BOC account to get through 1/10th of a full size bottle each year
    • FWD is different though.
    • Ignore the BOV / recirc valve question. You have an NA and shouldn't have one. If there magically is one though... It should be removed, though it shouldn't really effect it in the way one will for a turbo motor with it venting to atmosphere while running an afm.
