Hi
I am looking at buying a motor which has already been removed from the car but would still like a compression test carried out so I know its 100% good
Just wanting to know is there any way to compression test a motor which has been removed from the car, I have never heard of it being done but I am sure there would be some way to do it?
Its an RB25DET which has approx 80,000km on it so I would be expecting compression to be about 150 across all 6 cylinders?
Anyways any help would be appreciated
Thanks
https://www.sau.com.au/forums/topic/227594-rb25-compression-test/
Off the top of my head you could run a rubber wheel against the belts or crank pulley using a high speed drill or similar.
Removing all plugs first of course.
Or fit a pulley on the drill then run a belt to the crank pulley.
so it will be fine to crank it with the motor sitting on say an engine crane?
It won't jolt or twist when the starter kicks will it?
Thanks
yes yes it will jolt and try to twist.
removing the spark plugs will reduce this and allow the motor to spin easily, but this will affect the actual reading on the guage. you want all cylinders within an equal reading, the number it shows can be inaccurate
Alright thanks
What reading should be expected?
make sure it has oil in it
Will do
readings may not be quite as high or as even or as accurate, comp tests are supposed to be done when the motor is at normal operating temp. But should be an indicator.....I mean if the bore is shagged, it will still read low on that cylinder
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
