Hey Everyone.
Thought it was time I posted up a topic for my car. Haven't really updated anything since my first introductory thread (see HERE for my introduction post which explains how and why I got the car etc)
So it's a 1989 Nissan Skyline GTE, with a manual and RB25DE conversion, along with 5-stud brakes, R200 diff etc. It was purchased in October 2005.
A minor thing we did when we first got it was painted and cleaned up the brake calipers.
Before
After
We also got it dyno'd, 115rwkw, pretty reasonable I think.
Here is the progress of the Clarion Headunit and Front speakers. These were laying round from my sister's old Daihatsu Applause. No audio came with the car when purchased.
Before
Previous owner must have made these mounts, personally don't like them. Trying to source stock covers at the moment.
After
The rim centre's weren't in excellent condition so we decided to get them sandblasted and powdercoated in black. Also got the plates MI11NT, I don't like them anymore so when rego comes up I'm going to get RB25NA I think.
And then we did suspension, we put new Polyurethane bushes in the front caster arms and front upper arms, and a few months after that got TEIN super-street coilovers.
They're actually on their lowest setting, but I think it's great.
Sits nice.
Cat up to no good.
Another one of the cat
And then we got some better speakers for the front + tweeters (Pioneer) and moved the Clarions to the rear.
Not a great pic of the speakers but meh.
Not much happened for a while, but recently I got a new headunit.
No pics of that installed.
Also got a Genuine Nismo Steering Wheel and boss kit. I love the old style Nismo Logo.
And 2 days ago I got a Genuine Nismo Aluminium Chrome gearknob, however it isn't the type you can buy now, it's a discontinued part and has the old style logo engraved in it. Pics to come.
That's about all the progress on my car I guess.
My plans now are to get
  • Nismo Cupholder (rare) but just purchased one :(
  • Side Window visors
  • Fix + Paint front Aero bar and then purchase the matching Aero pods for a full Factory Aero kit.
  • Brand New Nardi Wheel (with Nismo horn button)
  • Mount rear plates at angle (and get RB25NA)
  • Stock door speaker covers and mounts.
  • Vacuum clean interior with one of those powerful chemical ones :O
  • Buff + polish + wax and all that stuff (easy done, just need to put the effort in haha)
  • Put some new Blue LEDs in the dash cos some of the ones now fell out due to the people putting the alarm system in
Thanks for looking at my 4-door R32 Skyline :P
Updates to come hopefully ^.^
-Jimmy.
Edited by -Jimmy-
https://www.sau.com.au/forums/topic/227599-jimmys-r32-skyline-4dr/
  • 1 year later...
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
