I have a question to the ether.
I am having a problem with the HICAS warning lamp coming on after around 15mins of driving.
It happens whether I cane it or not, and it has me a bit stumped.
Because it seems to be an event that happens after a given amount of time...it could be temperature related.
Other than that I have checked power steering lines for leaks and have not found any.
If anyone else has been through this traumatic experience and finally came to an answer I would appreciate the heads up.
R32 91 GTSt - pretty stock (no engine mods - only suspension and brake rotors)
https://www.sau.com.au/forums/topic/22760-hicas-light-problems/
hey dude sorry i have no answer.. but i have the problem too i have a 1993 180sx and the same thing happens i start my car ans let it warm up for about 5 min and then the hicas light comes on..plus some times my turbo timer poo's itself too so i let it warm um then before im about to drive off i turn my car on let it sit for about 30 seconds the start it up again my hicas light stays off and sometimes my turbo timer works properly too... hmm got me stumped too .. if anyone can help it would be mighty sweet of ya's ..
Guest xbellx
I have had a heart wrenching experience with Hicas lights. I finally solved the problem of the light coming on after five minutes of driving. It involved setting up the two sensors on the unit as follows. There is an input sensor & an output sensor, they look almost like a throttle positon sensor. the three wires are 5v positive, negative & output voltage. The out put voltages of both sensors must be identical, this is the key to the light not coming on. You must set it up with a multimeter on the output voltages of both sensors. adjust both sensors at the same voltage. They can go out of adjustment when drifitng & hitting gutters.
xbellx
Very interesting...I would be very keen to hear more about how this is acheived. If you have any photo, more detail please feel free to private message (pm) me, or even post it on this forum.
I appreciate your input...and I'm glad there are other Skyline drivers out there that have felt my pain.
  • 4 months later...
Just a quick note; After fitting a momo wheel and after market boss kit my hicas light would illuminate after driving in a straight line for 10 or so minutes, after further inspection i found that the boss kit was different to the standard wheel in that the hicas sensor had too much room to move within the boss kit. to remedy the fault i wrapped the hicas sensor's prong with some adhesive foam and then some race tape to keep it neat while the boss was re fitted. now the sensor sits perfectly central with the gap taken up with the foam. Hope this has been of some assistance and MERRY CHRISTMAS HO HO HO............ now to wrap more presents! :D
Yea I have the same problem as AutoTrust. Might try that little wrapping trick...haven't really been bothered with it coming on, but if anyone else drives the car on the highway for instance, it freaks em out.
Mildman, don't worry...you're not the only one with a HICAS problem! that's why we're all here :D
Hi Guys,
I have fixed my problem on mine it was the standard wheel or maybe it wasnt standard.
With the original the hicas sensor on the column was sitting about 30 degrees left, when i brought a boss kit and aftermarket wheel it sat top center.
This has fixed my problem no more hicas light coming on.
Hopefully this is the same problem some of you are having because it was simple to fix.
Dan
I fixed my 'HICAS twitch' by cleaning the battery terminals and re crimping the wires of the main harness leading to the battery. I found that a power fluctuation will cause the car to twitch sideways when the HICAS light comes on. Most of the cables leading to the battery had loose connectors. After tightening everything the 'twitch' went away. However the HICAS light still comes on.
I'll try the wrap procedure next.
Still would like to know how to do that sensor adjustment though.
can the self steering be fixed by disconnecting the battery again with the steering wheel straight?
Yes It Will fix that problem, you would have to turn your lights on and / or press the brake pedal to drain all power from the car, same as you do to reset the ECU. :)
I just got a new wheel & boss kit from santa yesterday and fitted it. I installed it yesterday but my wheel isnt at dead centre, i think its about 1 knotch out, and the HICAS light comes on after about 10-15mins of driving. Something to do tomorrow i guess, is re-align the wheel, and hope that the light doesnt come back on....
the boss kit is a HKB one, and i hope that it is the right one....
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
