Out of interest:
If you took 4 photos of a car from
i) the front
ii) the side
iii) obliquely from the front
iv) obliquely from the back,
What's the greatest car design you've seen of a car from the 70s (in stock form)???
(Was it the Miura; or perhaps the Alfetta GTV; or perhaps the Esprit Turbo, a particular Ferrari etc)
https://www.sau.com.au/forums/topic/227615-the-best-car-design-of-the-70s/
  • Replies 48
Bit of a failure this thread eh?
ACTUALLY THOUGH, >2 cars mentioned in the 80s section already were designed in the 70s !!!
Due credit goes to Lamborghini Countache which I saw at the SantAgata Lambo Museum 2 years ago. This place is a must see if you're in northern Italy. Much more friendly than the Ferrari Museum ' cause they actually allow you to see the factory floor.
Due credit goes to Lotus Esprit T. which is also a 70s design but with hardened corners to it. Seen Roger Moore in a white one?
Cheers, T
Was it the Miura; or perhaps the Alfetta GTV..
Did you mean the Alfa Romeo (105) 1750-2000 GTV? the bertone bodied cars were gorgeous, or are you thinking of the wedge shaped Alfa Romeo gtv6? it was ok but not in the same class.
The Miura and 2000gtv are two of my all time favourites..but both of those cars are 60's design.
A 60's thread perhap?...lots of sexy steel from the 60's.
Edited by madbung
Thanks for correcting me on the Miura which could be definitely conceptualised in the late 60s with the film Italian Job
The Alfetta GT is not as valuable as the 105 that you like so much. But somehow I like that 1974 shape that came out then and became the Alfetta GTV in late 70s as a 2 litre fast cornering bullet. The GTV 6 came out around '84 and won many races in Europe as well as here. It was made famous in Octopussy when 007 stole one and drove it like he...... well you know the rest.
My favourite design? The Alfa Romeo Montreal !
Oh yes...the Montreal is a honey and good buying atm.
Miura first rolled out in 66 and is still about the sexiest thing I can imagine on wheels, sadly it's way beyond my realm. Probably a $1mil + price tag by now.
Meh the Lambo hasn't aged well has it? give me a De Tomaso Pantera over a Countache any day...you don't have to be a midget to fit inside, you can repair-service it in your driveway and even better still it goes around corners.
They don't call them the "panty-tearer" for nothing :D
Edited by madbung
Sorry mate but i would take the Lambo any day of the week over the De tomaso... Lamborghini Countach would have to be the sexiest car ever built.... As for local cars i think the Falcon Coupes were the best looking things available... A9X Torana not far behind
I wouldn't know, I don't move in those circles...please tell me what the gossip is.
Can't imagine any Marys monstering one of those around the track, but hey if thats what you know..
Who am I to argue :bunny:
If that is a gay mans cars, grease me up and call me Nancy i'm ready to turn.
oops
Edited by madbung
does late 60's count? ie 67-69 SS camaro?
Why Not?? It was a real mean looking car with its open mouth; cool stripes across the bonnet and down the sides of the front quarter panel/
Engine? The big one had a 427cu.in. did it not. Correct me if you will
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
