yeah just disconnect the battery, pump the brakes a couple of times, reconnect the battery and adjust ure stereo and clock ;)
drive slowly around town and the 'Line will have a good fuel consumption (good for those times when ure broke)
or thrash it and it'll be more aggresive :)
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-488614
Yes it is safe to reset the ECU.
I think whether or not you'll notice a difference will just come down to when the ECU was last reset and what conditions it has adapted to. eg. When picking up a car straight from Japan, ppl usually notice a difference due to the varying road conditions ect.
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-490693
I resetted my ECU 2nd time a few weeks ago. It does make a difference if you put new mods on your car. This should remap it according to your new mods. Experience i had was from a standard turbo back zorst to a 3" turbo back. Without resetting my ECU on idle, it jumps from time to time. Now that i resetted it, it fixed itself and the idle now runs alot smoother.
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-490772
resetting the ecu, if you have 'no faults' will not make your car go faster or improve mileage.
The fuel and ignition map is exactly the same, before and after. The ecu DOES NOT remap. It will run the maps it always had.
I used to think it had some effect but after owning the car for almost 3 years I can assure you that it does nothing.
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-490944
It doesn’t change the maps but it dose change the computers range it will vary the map (within the ecu's factory range) resetting, erases the lean cruise data that the ecu learns which is dependant on driving style and it puts more advance into the motor because it hasn’t detected any knocks (pinging) yet. It also run's fuelling more aggressively.
A few hours of driving will pretty much set the ecu as its going to be and from that point its adjustments will only be slight. Hence resetting dose make a difference to power and economy. A reset should be preformed after any mod, fuel filter change, plugs, exhaust or whatever as the tolerances in which the car is running in have changed.
Regards
Damqik
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-490977
rev210: Gotta disagree there buddy.
For ages after fitting connecting my atmo bov, i had problems with stalling... I unplugged the ECU, and left it overnight.
Reconnected it in the morning, and now have never had a stalling issue since. It MUST have learned to not overfuel like that.
There's no other way to explain it...
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-491652
some ecus only have one map, others have two (high and low octane). the o2 sensor will determine if it is running too lean/rich when in closed loop. the knock sensor will determine if the engine is pinging and will pullback the timing where needed.
the maps themselves are not changed. but there is information stored in the 1K or so of RAM (early models) upto 32K RAM on later models. when reset, these will gradually relearn by large amounts gradually fine tuning. i think this might be stored in the ram and compared against the base map but this is only speculation until i do some more investigation into these. removing the battery overnight will dischange the capacitors which connect to the RAM chip and settings will be lost. car will run notiiceably shitty until it relearns the values again
im playing around with the following ecus... still learning about r33 ecu currently
http://imflame.ricetek.net/~darkhalf/ecu
matt
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-491830
AFAIK the ECU reset does change the ignition timing - advancing until the knock sensor cries 'enough' then retarding. It does this in progressivly smaller and smaller increments.
Here is a chart of my ECU being reset on a dyno (red line is the initial run straight after the reset, black line is a second or third run):
Cheers,
G
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-492019
I can explain it as I explained it earlier.
Unless you have a 'problem'.
Sorry the dyno chart proves there is nothing happening with a reset, contrary to you thinking it was.
GraemeWi,
by the looks of the dyno the first 'red line' shows an ignition fault similar to dirty plugs, after a few good runs particularly with platinum plugs they will be 'cleaner'. There are 'bumps' present still in both charts indicating this is the reason for the difference. Each subsequent 'power' run will slightly improve the condition.
In 'Closed loop' operation , the oxygen sensor may be re-calibrated on a reset. But it's 'closed loop', meaning very light throttle only.
Like I said it does nothing.
https://www.sau.com.au/forums/topic/22762-resetting-the-ecu/#findComment-493138
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
