For turning a love into an obsession :).
Its like... The more time I spend on these forums the more time I find myself spending around the car even if its not necessary. It started with reading the "You know you drive a Skyline" thread, which pushed me into cleaning the interior of my car, which lead to me scrubbing the engine too, then washing it thoroughly, and last night, I went out with some mates, and it was pouring, and when I got back home, I found myself in the garage with the chamois cloth drying my car up, even though I had to leave my house in another 2 hours which meant it would get wet again. And it did... And there I was at 12 30 am last night, in the garage, with the chamois...
So what can I say? I blame all of you guys, but then again... 'She' deserves the attention.
Edited by Romanian
https://www.sau.com.au/forums/topic/227669-i-blame-you-guys/
Obsessive compulsive disorder O.C.D
It's treatable but it'll always be with you
Goodluck...now go and check your car for insect footprints, they're everywhere you know :)
Damnable bugs!!!
Lol, ah yes. I must press the on and off alarm buttons 27 times or the world is going to end!
I also flutter 9 times at each traffic light or Commodores will become better than Lines :D
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
