Hey everyone,
Just got the engine for r33skizza in from the mainland however it has no flywheel and we really need one as his old flywheel happens to have a wavy pattern in it when running your fingers out from the center. So if anyone knows where we can get one from fairly soon as the engine needs to be back in the car and be ready to be tuned before next weekend.
Cheers
https://www.sau.com.au/forums/topic/227675-wtb-urgently-rb25-manual-flywheel/
Hey everyone,
Cheers
Just get it machined, any engineering place with a lathe can do it.
the problem with it was it had been light weightened and machined in the past and it looked way to thin to be re machined especially after seeing the heat marks through it.
thanks gesty but we picked up an rb30 one today. its done the job nicely in and running.
shouldn't you be watching drift videos or something damo
no we watched how it was done then went and did a bit in the rain. blew a cooler pipe off (thanks pete) had to get the girls to bring out the commo full of tools, did a bit more then went home. clutch feels good car feels strong and it hardly reads on the knock o meter.
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
