  • 3 weeks later...
  • Replies 91
production has already started . Hopefully a couple of weeks away.
Sweet, thanks mate, could you give me a heads up when they arrive???
ta!
well vi-pec was installed on monday just base tune map as dyno was busy .
car was dyno'd on tuesday and it makes similar power to the mines ecu i had in it
am extremely happy with the autoworx sales and service and am wrapped with lumpys tune
it still needs a bit more of a tune once i have found a stock 32 r boost solenoid as the bleed vleve in mine boost drops from 15 psi @ lower revs down to about 11 psi @ peak
YAYYYYYYYYYYYY no more AFM's to worry about
If you can't find the solenoid let me know. I have one at home you can have.
You've got an Rb20 solenoid??
Mark... its not the RB20 solenoid you're after, its the RB20 wastegate actuator :banana:
Edited by NISZILA
  • 1 month later...
woot woot :D
might call in early next week and pick one up
would you have the stock na rb25 neo map for it? I might plug it in before i do the conversion to see what the old na can pump out haha
finally got tune for boost and launch control done
dyno sheet
it boost was deliberately tapered off at the top end to stop the turbos over spinning and killing their frail 14 year old ceramic insides
very impressive result given its a basically stock 32gtr!
have you had a chance to try launch control?
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
