  • 3 weeks later...
  • Replies 91
production has already started . Hopefully a couple of weeks away.
Sweet, thanks mate, could you give me a heads up when they arrive???
ta!
well vi-pec was installed on monday just base tune map as dyno was busy .
car was dyno'd on tuesday and it makes similar power to the mines ecu i had in it
am extremely happy with the autoworx sales and service and am wrapped with lumpys tune
it still needs a bit more of a tune once i have found a stock 32 r boost solenoid as the bleed vleve in mine boost drops from 15 psi @ lower revs down to about 11 psi @ peak
YAYYYYYYYYYYYY no more AFM's to worry about
If you can't find the solenoid let me know. I have one at home you can have.
You've got an Rb20 solenoid??
Mark... its not the RB20 solenoid you're after, its the RB20 wastegate actuator :banana:
Edited by NISZILA
  • 1 month later...
woot woot :D
might call in early next week and pick one up
would you have the stock na rb25 neo map for it? I might plug it in before i do the conversion to see what the old na can pump out haha
finally got tune for boost and launch control done
dyno sheet
it boost was deliberately tapered off at the top end to stop the turbos over spinning and killing their frail 14 year old ceramic insides
very impressive result given its a basically stock 32gtr!
have you had a chance to try launch control?
