  • Replies 91
im thinking about buying a pfc just because it has the controller
yet the extra bits of this one seem too good to turn down
when will you guys have them in stock?
and approx how much will they cost to tune?
so this new ecu is basicly like a wolf v5 plugin ecu ?
Gary, I've compared specs on the two, they are very close... but the Skyline plugin version comes in $500+ cheaper than the Wolf.
And looks like it will be more widely supported :(
there are plenty of ecus on the market which this one compares too
you will have to evaluate each one on its pros and cons .
Certainly this product is feature packed and priced excellently and we think support and reliability will be 1st class
Anyone know how much workshops would charge to install and tune one of these?
Approx $700
just waiting for time/day day to be suitable with lumpy
Edited by gazza750
not yet
Lumpy had a dyno organised for a couple days to do mine and other cars but something was wrong with it so it will be next week before it is installed and tuned
i was reading in the other thread about the installation
which one do you guys stock?
the one in the case or the board the uses the stock ecu housing?
plug in board is very easy to put in i pulled my mines ecu out and pulled the board so i could drill a hole in rear of casing to put the usb lead through so it willbe easy to access and then put it all together again in less than 20 mins
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
