Open Cruise 12th July
Guest trikdoutbuketofshit
I might come later tonight. Going out with a few friends for dinner and movies. They'll probably come too, which means I'll bring an RX7, a couple of WRX's and a couple more skylines... maybe even some others. Not sure on whos coming.
Someone who is going PM me your mobile number and I'll give you a call to see where you guys are and we'll meet up. :bunny:
Hmm may as well chuck this in too to be handed out for free drinks and food the following week
http://www.modyourcar.com.au/images/myc_la...arty_invite.gif
To hungover for the cruise, but the MYC party sounds the go for next week :bunny:
will be there in the stagea of not so much fury, will bring that dayz part for u mess, but i stepped on it the other day so its broken a little more :)
good stuff cheers for that.. ill fix it up no worries..... my baby looks so much better now needs a good wash tho.. see u tonight
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
