  • Replies 244
are these fancy pistons with 4 rings? or is it a new 8cyl?
nothing fancy...of lets count them together shall we
1 x top ring
1 x second ring
2 x oil rings
4 rings ha ha ha (done in the voice of the count from Sesame Street)
another great build up thread
top quality work there Dirt!
makes me very jealous, i havnt got my hands properly dirty in a good 8 months
skylinekid, you must have a grin plastered ear to ear, all the best mate
lol maby.... ill get excited wen its on the dyno gettin tuned lol
and wat fancy modifications have been down to ur block anthony... or is it a secret???
he's talking about de-burring (removing the casting seams)...i do it with STD blocks...N1's at this power level if balanced correctly are fine. Its engine harmonics that crack thin fatigued blocks so balancing is very critical...running a proper balancer is more important than de-burring. How many people would just bolt this stroker kit into a block assuming Tomei has got it spot-on...id say a lot...ive proven they are far from it.
yup yup thats what i was talking about..
well put it this way.... i trust paul with building this engine correctly the way he see's fit.... he knows that if the block cracks he will be getting a bad rep... and both me and him know he doesnt want that. for instance look at how fussy hes been with the head. he didnt want it leaving till it was spot on due to the fact of it was his rep that would turn to shit otherwise. but i left it all upto him so it was his choice to do.
new head is down in newcastle about to start gettin the head work done... new valves retainers and springs are in and ready to be installed. am very keen to see a photos of these fancy double springs u speak of paul?
ill take some shots of the good bits and post them up
new 1mm oversize inconnel valves...nice...very nice
titanium retainers...these are so light they almost feel like they are plastic
dual valve springs
Tomei 270 deg 10.8mm cams and Tomei bronze guides are ordered and on their way...combined with a stage 2 port job this is going to be one awesome head.
Edited by DiRTgarage
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
