  • Replies 244
  • 3 weeks later...
Main studs installed
final check of crank journals before fitting
bearings and crank fitted
girdle in, studs moly lubed and torqued in 3 steps
i was just sittin here looking at the main studs.... and for sum reason there is one odd stud right in the middle of the block it looks the same as the end studs... i ask u this because its the one ur holding the socket over in the picture i could see it better in down further.... just unsure of y its like that and the others arnt???
Edited by skylinekid
thats correct...because the girdle height is thicker there as well as the end studs...well picked up
re the arp mainstuds, are you using the special order rocket sets paul? i.e the ones with the 3 shorter 'long' studs?
dont know where these were sourced from...let me guess...they foul on the windage tray?
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
