what was your A:F ratio and timing in the top end on each?
your profile says your in adelaide but you say the car ran the nurburgring (or is that a copy cat in SA called nuerburgring?) what fuel was is tuned on and was it constantly getting the same fuel? or have you jumped countries and changed fuel without the tune to suit? is it possible all 3 cars got a dodgy batch of fuel from the same servo/area?
did you tune the cars on dyno or road?
i wouldnt focus too heavily on it always being cylender 6, as i personally think its just motor design. just get rid of the problem
Yes very interesting . Has anyone ever set up crank pulley and flywheel position sensors to see how much variation there is along the length of the crankshaft at various engine speeds and power loads ?
Cheers A .
was a few years in adelaide thats why
here pics from 13.07.2008 =)
PS yesterday on the NÜR the piston rings are gone
Edited by JapanDyno.com
  URAS said:
give your tuner the right nine :laugh:
how old is the A/F gear your using?
no idea how old the gear is i changed the tuner twice,
About fuel pump
the R34 had a Nismo pump and the engine is abit white inside was running too lean understand easy
but the R33 also had a GTR pump and
alot people say here its too lean right ?
so the problem here is again the A/F ?
now are 3 engines to rebuild 1 Neo and 2x Series 2 Rb25
if anyone can tell me some good tips to take care of please let me know
thanks for any help
im just sick of spending money to rebuilt them and then soon or later something happens
dino
Cheers A .
Havn't seen this issue in the XR6T's and thats up to about 700rwhp at 5500rpm on the standard crank and I'm pretty sure there would be alot more torque in a tough XR6T than most tough skylines. And as for over advanced ignition timing being the only thing to cause engine failure thats a crock.
slightly off topic but from my personal experience on my rb26 and a mates one as well with totally different setups (both over 500rwhp) we both run individual egts in each runner and they show 5 and 6 the hottest off boost and cruising but on boost 3 and 4 are hottest by a fair amount, even with 4% more fuel in 4 mine is still getting 20-30 degrees hotter than all the other cylinders. We both have had our injectors tested and they are spot on as well, im interested to see proof of no 6 cylinder running the hottest on boost as everyone seems to say?
Did you calibrate the thermocouple's in the operating range as alot of K and J type thermo's are quite inaccurate from sensor to sensor.
they are innovate dataloggers (tc4's) and RTD thermocouples, it says nothing in the instructions about having to calibrate them, how would u go about doing that? put them under the same temp condition and measure the temp readings i assume? whats the best thing to use to calibrate them then.
perhaps to test them yourself is go for a drive.. data log it.. than change the sensors around.. than go for another drive and compare the logs to see if the differences between each cyclinder change much at all
Smart cookie
  unique1 said:
...on boost 3 and 4 are hottest by a fair amount, even with 4% more fuel in 4 mine is still getting 20-30 degrees hotter than all the other cylinders.
Have you guys come up with any idea's as to why this occurs on 3 & 4...?
... maybe its the reason CRD and others are big on multi point, head coolant relief setups.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
