Iv been following this for half a decade now. Only today thought others might not know of it. Did a search for "DP1" - nothing mentioned.
http://www.dpcars.net/dp1dsn/index.htm, then click the 1 in the top right corner, to take you to the 2002 design start.
The work and access to quality commercial industry work is mind boggling. I THOROUGHLY recommend brewing some coffee, and sitting down to read it from start to finish, if your at ALL mechanically minded. Keen an eye on the log dates, and the sites a little raw, and you can find yourself getting fast forwarded.
Enjoy :D
Edited by GeeTR
https://www.sau.com.au/forums/topic/227754-dp1-ground-up-track-car/
Glad uv enjoyed. Iv was obsessed a fews back about making a tube frame (think edge buggy with slicks) with a 1L turbo bike motor, alas it been regated to the 'list" :bunny: When you really look into the inherent driving characteristics of an all out, track cart with almost more HP then KG, it can change the way you see your own personal motorsport requirement :P I'm happy pouring all my $ into my squishy 1.5 tonne road car for now lol.
Bump bump! :D
Not being a wanker, just making sure ppl get exposure to this thread. Its intensely impressive reading about someones desires, and how they translate into CAD designs, more thoughts, manufacture then use. Its a auto mech eng wet dream.
GeeTr,
This an awesome find.
Im a few pages in and being from an Industrial Design background, im finding it engrossing. This guy is doing everything right and it seems money is of no concern so all power to him.
Its refreshing to see someone go at a "project" like this in a major way. Top stuff.
Cheers for the link.
E beer fer ya. :ermm:
Spotted this thread almost a week ago, have returned having gone to have a look, and ending up reading pretty well the whole site :| (Reading about the current and past cars/bikes is extensive to say the least...)
Absolutely awesome.
Honestly I still have a stiff I think. Can't believe the engineering nous used and general level of detail and effort involved...
Im staggered. Pure awesome. Thanks so much for sharing :laugh:
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 馃
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
