to change gear oil:
get it up in the air,
whip out the two plugs that a half inch fits into,
let oil drain out,
replace bottom plug,
fill with oil until it starts coming out of top plug hole
replace plug
easy!
Edited by cuppas
it will only shift into 5th after car(or maybe gearbox) warm up,like start the car warm up2-3 mins,diver to a freeway,i can clearly see,the rev stay under 3000rpm@100km/h. but after travel 10km stationary speed,can feel it sfit 5th,and rev drop back to 2600@rpm@100km/h . is that still normal?
  • 3 weeks later...
I'm not 100% sure but that doesn't sound right. I thought it was 4-speed autos only for the R33.
dont konw it is 4sp or 5sp,but i definitely can feel that final shift,or can see from the rpm instrument(4th 2800@100km/h 5th 2600@100km/h <or called factory extra>).
i think the way to find out how many speed of the gearbox is count the how many times it shift.which is means 4 shifts u got 5 gears or what ever the factory extra,am i right?
Well yes and no.
I'm pretty sure it's only a 4 speed auto box in the R33. It may possibly have some sort of overdrive or something, in which case that could be mistaken for some sort of 5th gear.
Searched the net, it always comes up with: "The RB25 turbo comes with either a 4-speed auto or a 5-speed manual".
So if it is some sort of overdrive, then I'd expect to only come on at high speeds (~100km/h) and only once the car was warmed. I wouldn't think any more of it, either way you don't have a 5th gear so there is nothing wrong with your gearbox. Plus, anything under ~3000rpm at ~100km/h is fine. My manual R33 sits at ~2700rpm in 5th on the freeway.
Well yes and no.
but it will come up when car warm at low speed,1600rpm@60km/h,if not it will reach low2000rpm@60km/h
