Those Blitz units are a bit old, whereas the avc-r are current units. Hey, it depends on what you want. If you just want an EBC just to control boost, then the Blitz is fine. If you want and EBC with bells and whistles, then you cant go wrong with the avc-r, E-01 or SBC-iD III. Considering some shops sell the AVC-R for $1200-1300, $700 is good value.
https://www.sau.com.au/forums/topic/22783-pfc-and-ebc/#findComment-491796
  • 1 month later...
HKS EVC is the best by far! :D
rs73, you can just leave the factory solenoid there, but u have to pull one of the vacuum hoses off and put it onto the stepping motor.
also, 2nd hand boost controllers are good value, but if the stepping motor goes, then your only option is to purchase a whole new unit.. which could cost you more in the end.
a HKS EVC 4 your looking at around $990, so they are no cheap, and a fair bit more than the AVC-R.
Other option is the boost control kit for the pfc, but it can only be changed using a handcontroller which i think would be a pain.
https://www.sau.com.au/forums/topic/22783-pfc-and-ebc/#findComment-558541
Hi,
Thx for the reply.
I actually found an HKS EVC EZ-II, which is exactly has the same Stepping Motor & Control Unit found in the HKS EVC 4. Price is quite a bargain at less than $650.
The unit is upgradable to full HKS EVC 4 by buying the optional screen which part# is provided in case I wanna order one. I decided this is the best one to go as I can add the screen later when I have a spare $300 lying around. The screen adds a "beep beep" overboost warning function :D and password protection, and scramble boost, which would not be really needed for my everyday use right now.
It's sitting right here @ home, cant wait to put it on...
Dave, is it still possible to remove the factory solenoid completely? as I was told that the factory solenoid can sometime interferes or confuses the ECU when used in conjunction with aftermarket boost controllers.
https://www.sau.com.au/forums/topic/22783-pfc-and-ebc/#findComment-559056
Originally posted by 2fardown
Only $700??  That's a lot of money to spend on a boost controller.  You can pick up second hand Blitz units for $395 from www.hikariperformance.com
Agreed. Too much to pay. I bought a blitz twin solenoid unit off these forums for $250 and it works a treat with the PowerFC. The trade off is your Commander won't/can't display boost pressure - easily fixed with a gauge.
https://www.sau.com.au/forums/topic/22783-pfc-and-ebc/#findComment-559737
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
