I think its the "A prestige touring wagon......." thing I have seen some people around here quote.
Someone should know!!
Nah - thats a sticker found on a lot of RS's something about a functional yet comfortable touring wagon.
Its like a set of mats I saw on ebay a while ago.
It had (stitched into the mats)
Pulsar
Feel the beat (lets drive) with more enjoyment as our feelings dictate.
They rocked, but some fool paid almost $400 for them and I didn't like them THAT much.
I really wanna know what it says now :/ I bet it was something damn funneh.
  • Replies 40
Mine is exactly as it appears in the sales brochure!
I did have P1 light weight wheels on it, but the R34 wheels went back on today due to the P1's cracking twice..
hey dude, you would happen to have those rear flares from the new set you got sitting around would you? wana sell em if you do?
D.
  • 2 months later...
No, I can see that bit, I was talking about this stuff.
Finally have an answer for you on this one, Mr Rooster. It says:
"Extremely outstanding specifications will lead you to the world of intoxication and help you relieve all emotions"
ROFL!
I would have preffered 'a prestige touring wagon that is comfortable yet functional' which is what i was thinking it was.
But that is just sweet haha
I think the whole car looks awesome - id even keep the stickers on it. Its a hell of a statement, the whole car is.
wats a drive meter? does that show your speed or sumthin or is it a tacho?
I had one in my car but i pulled it out and replaced it with a boost gauge, still got it in the garage somwhere. The drive meter is simply a tacho with digital display reading as in if your car is doing 3500rpm it reads 35 on the display and it has a colour display which as you go up in revs it goes up from green to orange to red and also has a shift light which conveiniently flashes at 3000rpm which is around when your turbo spools up. i dont think it can be adjusted though which is pretty poxy.
Headlights??
Sweet looking ride, uve done well there. id say thats a pretty rare car especialy having all those dayz options. keep hold of that one it will be worth alot one day. Mines has dayz options to but mine only came with front bar and rear lip and skirts, carbon instrument cluster backing, rear bagde. id like to order some other options if there available.
ROFL!
Oh lawd :(
That is farken GOLD!!
Here you go! If you want one with all carbon trim the same as mine.. Here it is..
http://cgi.ebay.com.au/2000-Nissan-Stagea-...A1%7C240%3A1318
Can someone tell me the part number for the Dayz front bar. Would like to see if it's cheaper buying new or getting mine repaired. Anywhere in Australia that makes the Dayz bar?
No one makes the Dayz bar! You'd have to find a second hand one if you can..
I would look at getting yours repaired.. I got hit from behind a few weeks ago and I am in the process of getting my one repaired as well.
Plenty of Dolphin kits come up in the ads if you wanted to get one of those..
Hornsby Nissan gave me this: "K60200V750 WHICH IS A FACTORY AERO ACCESSORY FRONT BAR COVER AND DOES NOT COME COLOUR CODED. LIST PRICE IS $2873.89"
You would have to check this yourself. unsure whether SI or II problem being I believe they are the same part number.
    • Which are almost all nonsense. Ignore. Obviously enough, if it is not a porous block, then any such thing is a waste of time. External block surface? Would be a waste of time, if the block was actually porous. It would need to go on the inside, which is inaccessible, and even if the block was open deck so that that area was acessible, it would be unlikely to work. But seeing as this is all nonsense, stop worrying about it.   If the coolant is coming from the side of the block it is 10:1 odds that it is either a welch plug, or it is coming from the head gasket. Maybe from one of the coolant lines feeding the turbo, or even the heater. Liquids that leak from up high can travel sideways along casting surfaces or pipes, etc on the engine before finding a spot from which to drop.
    • Yeah rust is sadly also a bit of an issue on my car. Doubt there is many cars out there that actually have no rust in those aeas. The strut towers look fine but some of the surounding metal sheets show a bit of brown cancer peeking out from in between. I hope I can make do with external remedies and won't have to rip open the whole front end anytime soon. It looks somewhat minor compared to some shit I have seen online. I have worked on a few cars but I expect the RB26 to be my first 'engine out' job at some point.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
