Imported Cars Needed For Photography...
fullyhyperlite
 Share
  • Replies 203
Ok guys, just bumping this for a quick update:
Final details for the cruise are being made over this weekend, shall be done by tomorrow arvo/night (when i get home from Autosalon lol)
Annnd then.
Details and route shall be sent out via PM, upon request.
So then theres no random commonwhores and whatnot haha.
Turns out, unlike my previous update, of there only being 2-3 photo stops....turns out i have about 6 now thanks to some help from Jack :cool: haha.
So lots of variation.
I'll post again in here when things are ready tomorrow!!
I can stop buggin ya on my space now Charmaine :cool: lol! xo
Haha myspace is gunn...i tried putting it in my sig but it came up wrong cos obviously you cant swear on SAU..
its comes up like http://www.myspace.com/ratmf**kingrock
except those stars shouldn't be there lol. damn! haha
YAYYYYYYY!
Fantastic! I come home from school and SAU is working again!!
Ok, for those who don't know/don't remember :sick:
My cruise has been organised for THIS SUNDAY (17th) afternoon.
Route has been typed out, and i managed to send it to a few, whos numbers/emails i had.
If ANYONE else is interested, comment in here or chuck us a PM with your email address in it
and i can send you the route details :ban:
Any questions on anything just let me know.
Cheers!
:O
Haha well like iv said to Luke, if you wash it and it rains.....
i shall wash and polish it for you afterwards*....but at my house so then people think i have a sick car :O:sick:
EDIT: *Terms & Conditions apply
Edited by fullyhyperlite
9 pages of talk about a cruise...
Have we reached an agreement yet?! :thumbsup:
Haha yeessss!!!
Do you want a PM with details? :D
And yes Damo you CAN be stuffed driving all the way from north, to go further south and then go back north.. Look do you want me to take photos of ya silly car or not?? :):D All you do is complain.....must be a northerner thing...... :D:)
 Share
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
