Hey Guy's ,
I have heard rumors that Australia wants to make a similar TV program like Top Gear and Fifth Gear ? But our Aussie version , anyone heard ?
Have you heard this before ? :D
Or is this just another crap joke ! :)
Regards Mario :D
Edited by PolishDoc
Yeh this might be on another thread - but I didn't have time to answer it.
I believe (if I'm not wrong) that Oz gets its own version and USA gets another.
3 on the panel - hopefully with 1 manic like Jeremy, 1 talkative and appealing like Richard and 1 coy & witty like James.
1 on our panel is Crompton who took one famous R32 GTR to 3rd place in 1992 Bathurst 1000.
Other guys will add heaps more than me.
Cheers, T
yeah they have been like advertising it for ages now.....a few months even.
they even had after the top gear show a promo to host top gear aus....anyone could enter!
Cheers, T
Terry,
Who do think will take a similar position to Crompton ?
Regards Mario :)
Edited by PolishDoc
All three presenters are listed on the SBS top gear website, also has info on all of them
LUKE ,
Do you have a link besides the youtube one ?
Regards Mario :)
Edited by PolishDoc
I wonder who is going to win ?
Regards Mario :)
    • Yeah. If I plug the connector in and connect the vacuum lines, I assume worse case scenario is that it simply doesn't work? Yep PFC.
    • I would think that rather than attempting to perform an engine swap, with all the difficulties associated with doing so in a country where the raw materials required are harder to get hold of, I would just build the CA20 for boost, find an EFI manifold for it and either add a turbo or a supercharger. Or both. You replace one set of difficulties with a different set, but I know which would be more fun.
    • Well, a proper aftermarket ECU** SHOULD be set up to run the purge solenoid, same as the factory ECU would, so that the tank breather system continues to operate the way it is supposed to. I have no knowledge of whether the PFC (which is what I assume you mean when you say Apexi) has an output (and internal logic) to run the purge solenoid. If it does not, then given the product design intent for the PFC, which is to be a plug in replacement for the stock ECU, I would consider that a massive failing on Apexi's behalf and would be another reason to think that they were a half-arsed solution to the problem if programmable management on RBs. I would suggest that since Nistune came to market (which is a LOOOOONG time ago now) there has been no valid argument for choosing a PFC, especially if the PFC can't do things like this.   **ie, Haltach, Link, Motec, etc
    • Thanks for asking the question we were all thinking!
    • Does this apply if you use an aftermarket ecu as it probably doesn't have that functionality built it? (Assuming it doesn't, in my case, apexi)
