1) if they are installed properly, they are very good and will support over 600hp.
2) seen them from about 400 - 550
3) They are a bit tricky to get in, some of the fittings can be hard to find. If you do a search, there is a good thread that covers installing pumps not too far back.
What sort of hp are you chasing? Cos there are some other good options available that are cheaper and easier to install.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-488910
Do they have a mounting bracket that sits the 044 pump properly in the right spot or do they re-use the old bracket? Because mine is a little bit mangled :) I wouldn't mind buying something that puts it in the right position. At the moment I'm contemplating running a longer hose to pick up the fuel from lower.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-489988
Originally posted by INASNT
$320 with all the fittings. Just got mine installed. If u know em then u get the good price otherwise :shake:
jee u must know them well,i havnt seen them under $300 and i have bought a few,just bought 2 for my r32 and cost me $600 and then to fit intank and do it properly you need about $75 in fittings and also labour to fit into the tank.
u paid $320 for a $450 minimum job,are u sure its not an 040 or another brand pump.
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-498336
Guest INASNT
i got a whole bunch of stuff done so the labour costs aint that much just for the pump
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-498629
No surge for me unless I'm below the empty line on the gauge (<8-10 litres). I know why it's doing it though, it's because the pickup doesn't go as far down into the tank because the pump is in a different position. One day when I can be bothered I'm going to take it out and put in some longer hose so it gets the fuel from further down in the tank.
If yours is doing it with half a tank you probably have a dodgy install. Have you got the original pick-up fitted to the bottom of the pump or is the fuel going straight into the pump?
https://www.sau.com.au/forums/topic/22787-bosch-044/#findComment-499190
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
