And also, the Z32 will support air flow up to around 55-60lb/min. So if you're making that kind of power, I would suggest changing to the new VIPEC ECU or a MOTEC/AUTRONIC/HALTECH and stop mucking around with a system that is not going to get you anywhere
https://www.sau.com.au/forums/topic/227873-nissan-q45-afm/#findComment-4010364
Engine
Rebuilt Engine
Ported and Polished Cylinder Head
GREDDY Racing Timing Belt
GARRETT GT35R .86 Ported Shroud And Chrome Housing
Topmount Exhaust Manifold
TIAL 43mm Wastegate
HKS Downpipe
HKS Ground Cables
COMETIC 1.5mm MLS H/G
TOMEI Procams 260 Degree 10.25mm Intake Camshaft
TOMEI Procams 260 Degree 10.25mm Exhaust Camshaft
TOMEI Procams 10.25 Lift Type B Valve Springs
TOMEI Forged Solid Lifters
TOMEI Cam Pulley IN/EX
TOMEI Adjust Shims
SARD 550cc Fuel Injectors
NGK Iriway 8 Spark Plugs
Z32 AFM
APEXI Power FC Standalone
Engine Exterior
HKS HYPER Exhaust System
HKS Type R Intercooler
HKS Oil Cooler
HKS Ground Cables
CUSCO Oil Scavenger
NISMO Fuel Regulator
WALBRO 255L/H Fuel Pump
TEIN FLEX Coilovers
TANABE SUSTEC Strut Tower
OS GIKEN Twin Plate Clutch
BLITZ SUS POWER Air Filter
I was making 413hp on wheels on 1.7 bar of boost with the setup above.
Somehow i f***ed my oil pump and bearings where i have predicted it'll happen.
Now im in a process of rebuilding my block with Wiseco pistons, GTR rods, ACL bearings and a JUN oil pump.
Im looking for a Q45 because my airflow reading is at max. Im currently using PFC and if possible i would like to upgrade the PFC to a FCON.
Im searching for a complete set of RB26DETT plenum and runnersas well.
https://www.sau.com.au/forums/topic/227873-nissan-q45-afm/#findComment-4010768
