Got lots of parts left over from wrecking my '93 R33 GTST. All parts are in good working condition unless otherwise stated.
1. Air Con Pump - $150
2. Gearbox mount - $40
3. Manual Dash Surround - $50
4. Clutch master cylinder + Slave cylinder with Maltech braided line - $100
5. Starter motor - $100
6. Throttle body with TPS - $50
7. Brake cyl with reservoir - $50
8. 2 X o2 sensors, one only done 500km - $20 old one, $50 new one
9. Alternator - $100
10. Power steering reservoir - $20
11. SMIC with pipes - $40
12. Turbo Inlet Pipe - $30
13. Handbrake with no cable - $20
14. Front rotors, require machining - $40
15. Boot lid with S1 Spoiler, Black. Has 1 pindent and 1 deepish scratch - $50
16. passenger door, Black. Perfect conditiong. window has dark tint - $75
17. Passenger seat, no rips or tears. Needs a good wash - $50
18. Radiator - $50
19. Lowered Springs - $40
20. Turbo Heat Sheild - $30
21. Automatic Tailshaft - $50
22. centre compartment - $30
23. carbon Cannister - $20
24. Engine Mounts - $50
25. Radiator overflow bottle - $20
26. exedy 5 puck clutch, 3000K's old. pressure plate in good condtion, clutch plate has damage from hard launches - $100
27. S1 front bar indicators.
Im happy to post anything at buyers expense, or pick-up is available from Emerald, outter SE melbourne.
Contact through pm or this thread. Cheers, Shane.
https://www.sau.com.au/forums/topic/227903-r33-gtst-wreck-left-over-parts/
Have Been sold.
Rest still up for sale.
CaLi - Don't know the brand of the springs as i brought them off a member on here about 2 years ago. They sit very low. Ive put a pic up of my car when they where fitted here : http://s160.photobucket.com/albums/t177/Shano3000/
The parts listed are the ONLY parts that i have. Everything else from the wreck has been sold.
S1 Front Bar indicators sold pending payment.
  • 1 month later...
Be very careful dealing with this guy. He sold me a dodgy gearbox from a R33 gts-t which ended up costing me over $1500 to repair back to usable condition.
When i rang him to talk about it he was an arrogant prick.
hey champ have u still got the O2 sensors???? if so pm me with info and ill take em off ya hands...... postcode is 2164 wetherill park in sydney's west find out how much postage will be and get back to me asap plz
thanx champ
daniel
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
