Hey Guys
Given up on my long term r33 project "Cant be bothered putting it back together" decided to wreck it.
Everything except front headlights and gearbox is available. So basically the whole is being parted out.
Car had 67klms on clock been sitting for a while now. Car is white in colour. Shell is complied.
Engine complete r33 series 2 (standard) with 67klms on clock $2000.
S2 AFM $125
climate control $80
s2 engine harness $250 uncut
charcoal cannister $60 (smaller size type)
ac Fan $100
hub/fan $100
Radiator $100
rad. shroud $70
Condensor s1 $100
gaurds $100
s2 front bar cover (black in colour) $200
front s2 fog lights $250 pair
bonnet $350
side skirts $200 pair
complete r33 s2 airbag set drivers/passangers/dash etc $800
s2 cluster $250 with 67klms...
s2 front grill $100
rear tailghts $100 complete
rear bar $100
rear garnish $70
Doors $200 each
boot lid $100
s2 boot spoiler $100
Stealth wing $160 . black in colour.
T wing (optional with stealth) $100
drivers s2 switch $90
rear parcel tray $100.....
S2 dash surround $150
complete interior $600......happy to separate seats trims etc.....
tein adjustable coilovers $750 for the set fronts and rears
s2 diff $250
After market airbox + filter + adapter $120
rear / front lower control arms $100 each
SSR rims 17 by 9inch rears / fronts 17 by 8.5 $600 (rims only atm)
complete 5 stud conversion $800..happy to separate suspension also..........
happy to separate the shell eg Radiator support, rears quaters etc. Please Ask.
PLease pm /post here me if there is anything not listed..im sure i have forgotten heaps....need to sell everthing no more time or space :) Parents onto me to clear everthing lol.
some pics attached
thanks SAU!
https://www.sau.com.au/forums/topic/227923-r33-series-2-wrecking-my-x-project/
  • Replies 63
Posted Images
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
