  • Replies 54
apparently USA uses 91 octane which when converted to RON works out to be 98 RON
America's "octane rating" is the average between its RON and MON rating. If I remember correctly, and I probably don't, their 91 octane works out at 95RON and their 93 octane comes out at 98RON. It was only a few points off.
However, since neither is commonly available outside the major cities, they tend to tune for a lower grade fuel than we would.
I'm not sure why the Stillen kit was suffering emissions. It could be the Stage 1 aspect of it (the lack of intercooler), and so it might just be dumping extra fuel in whenever it overheats (all the time) and killing the chance of it passing. Its more than possible that a Stage 2 kit, with its intercooler, will not suffer the same fate.
I was talking to Peter Pilkington about it (he used to prep the white 350Z in Nation's Cup for his son Nathan), as he was at a track day where they were running the car and he had a chat with them about the vehicle. It was out the same day that the owner of the white V35 that now runs the 4.2L engine and APS Extreme TT kit popped his original motor at Wakefield.
You got it, but every US tune I have had anything to do with is very unresponsive due to a general lack of ignition advance. When I talk to the tuners they all use the "low octane" excuse for the dowiness.
also, reliability is a big issue in my mind
Then avoiding the combustion pressure hit at low rpm should be a priority, a softer, more progressive boost build would be my objective.
gary, do you believe that a TT setup will work reliably on a stock motor with an auto transmission?
I actually think turbos and autos go together very well. The Stagea is brilliant, just load it up against the torque converter and make 12 psi or so for take off. It never drops off boost because you don't lift off for gearchanges, there is a constant stream of exhaust gases.
the stillen kit is designed to do so and has proven to do so before
I can't see how a supercharger would be any better.
also, the stillen kit is CARB approved, which means it meats californian emissions standards. this to me means it will easily pass aussie testing
CARB rules are a bit unusual, they are in general terms tougher, but the California temperatures, rpms and speeds for measurement of emmissions are unique in the world. I wouldn't feel confident that just becuase a car passes in California that it will pass Euro 3. The fuel differences just add to that.
is supercharging the easiest way to make the most power?
Not everywhere, because it soaks up power driving the supercharger itself, so you actually get less power until the boost reaches a point where the horsepower produced exceeds the amount soaked up. Have a look at the idle A/F ratios, throttle bypass and the amount of ignition advance required to keep a stable idle with the supercharger load added to the power steering aircon and electrical loads.
no, its not. but in my eyes its a reliable way to make more power on a stock engine with an auto trans and to meet aussie standards
I'm not convinced that a supercharger is better than a turbo charger for an auto. As for meeting the standards, that would have to be proven locally.
also, imagine the low-rpm torque!!
Precisely my point, I don't think it's a good thing. Remember the Yanks like to make every engine feel like a big cube V8, lazy, unresponsive torque is the target. They don't want a responsive lively engine, they want a slugger, hence the aftermarket responds to that requirement.
thoughts gary? specifically on the stillen kit?
I have zero experience with the kit, plenty with superchargers though. I have enough confidence in Stillen's previous stuff (I have used a few bits over the years) to believe that the kit will do what it's supposed to do. My personal difficulty is that I simply don't like what it's supposed to do, plus I am not big fan of the endless supercharger whine that Eatons generate. That's just my own preferences and may not reflect other people's desires.
Cheers
Gary
Gary, Alan
What's your view on a custom turbo kit built here in Aus? I imagine that everything is mostly easily doable, except the turbo manifold(s).
Any view on this?
I know the HKS kit your referring to, and it looks great, but again your paying for HKS parts.
Do you see any major problems for a knowledgeable workshop to develop a custom kit?
My view is that there is easily enough experience in workshops here to develop parts such as intercooler piping, exhausts etc. Things like ECU's Turbo's, injectors, fuel supply can all be done here without much concern. Again its the manifold that I'm worried about.
Does anyone have any experience with a custom manifold and pricing involved?
I know someone with a HKS ST on 350Z-Tech. You could ask him for a photocopy of the Bill Of Materials, if one came with the kit, (or use the BOM for the APS ST) and try and replicate it as best you can using local parts.
I have no idea what turbo APS uses in their ST kit either, but HKS HKS uses an externally gated GT3037.
This is the kit
If I add up the parts, turbos, manifolds, sump, inlet pipes, fittings etc (even using Garret turbos), I don't think I could do it for $6K (the US price). Certainly not significantly cheap enough to make it worth my time engineering it myself.
Cheers
Gary
gary,
thanks for your thoughts. you make some interesting points re tuning, especially idle tuning with a supercharger
my knowledge of the stillen kit is that the blower is bypassed at vaccum intake pressure or somthing along those lines. not sure how this affects things.
i agree that the supercharger isn't the easiest way to make the most power.
but i think its a cheaper way to make more power, and probably enough power for my liking. i especially like the idea of an easy install with no tuning required to still make +30rwkw or even more
my auto currently has a BIG trans cooler, and i'm not going to touch it any further
all i will add to the car if i get some kind of FI is LSD and maybe an oil cooler
i'll keep doing some research and keeping an eye out for second hand kits. if i find a second hand centrifugal kit i would also consider that...
gary, any thoughts on the under-bonnet temps of a TT kit? and also, how running 2 turbos would alter emissions especially cold start emissions and the lack of heating up ofthe cat when running turbocharged setups?
Edited by WazR32GTSt
bobby.. what about a VQ25DET manifold (M35 stagea).. would that fit up to the VQ35 motor?
Hi Warren,
The VQ25DET has a "very" unique flange on the manifold for the turbo. It has been described to me by people who work with high flowing turbo's as the first time they had seen that flange and turbo housing.
Cheers
Andy
gary,
The turbos are rear/low mounted and consequently in the exit airstream from the engine bay. Based on the comparison of the low mount RB20 turbo (using the Group A R31 exhaust manifold) versus the standard mount, the low/rear mount turbo ran much cooler and the under bonnet temperatures were remarkably lower. As usual, I will thermo wrap the pipework wherever possible.
For cold start emmisions I will be locating the cats right at the turbo dump pipes, that ensures the fastest heat up time. The V25 single turbo actually has 2 cats, one small one at the turbo dump for fast heat up and one further back for running. Keeping that logic in mind I will keep the cats physically as small as I can, there are 2 of them so they don't have to be as big as a single would. "Small" doesn't mean restrictive, the matrix is smaller so it heats up faster. The downside is more frequent changes of the cats as the matrix wears out faster.
The "no tune" power increase for the turbos is exactly the same as the "no tune" power increase for a supercharger. The Stillen kits simply adds an injector downstream to add fuel when its needed. There is no reason why I couldn't do exactly the same with twin turbos. It's just a simple single (or twin) injector controller, they are cheap, readily available and easily tuned. They are just not able to be tuned accurately enough for larger power increases, plsu they have ignition tuning deficiencies. I have long term plans (forged internals) that will mean more power (~700bhp), so a tuneable, piggy backed ECU is the go.
Cheers
Gary
nice gary, a built VQ35 with a TT kit would be ideal on a track, and with a few handling mods.. hmmmmmmmmm..
i have ordered some sways off your son just waiting for them to arrive hopefully they make a nice difference to handling on the V35, i'm sure they will
what other plans do you have for the V35 you will get?
Waaaaaaazzzzz,
Have you been bitten by the performance bug?
First supercharging, now sways. What other dirtly little secrets do you have :-)))
Sways make a massive difference IMO.
Gary are yours adjustable? I ask cause there's ALOT of different opinions in the US on what settings suit the V35.
The NISMO set i have are fine for me as the car is 99% street driven, but imagine you would want a bit more flexibility for more track work.
haha yeah i have a fwe secrets, no point airing on the forum all that is going through my head :ermm:
i ordered a set of sways through matt (gary's son) and they are non-adjustible but much stiffer than OEM. there was a more expensive set that was adjustible but i won't see track time so i don't care. i oredered them about 3 weeks ago, can't wait to get them on soon!
i've also recently fitted a HUGE tranny cooler to my car which added over 1L of trans fluid to the capacity as well as cooling it significantly. i used OEM nissan matic J fluid - actually i have just under 4L of this left is anyone wants to buy the rest of the container for a cheap price!
Special Turbo System for Z33 will turbocharge VQ35DE.
Features- The kit works on stock engine. If engine internal parts are upgraded with HKS Forged Piston + I-Beam Conrod Set (23004-AN002) - Metal Head Gasket (23001-AN002), target horsepower will be more than 450ps.
- GT3037 Turbine enables strong torque from low rpm range even with stock engine.
- Size of intercooler is minimum with consideration of affect to water temperature.
- For emission problem and vehicle inspection, center pipe integrates HKS Metal Catalyzer. (With Exhaust Gas Test Report)
- Adapter Pipe (Sold separately) is required to use HKS Full Dual Muffler (32009-AN002) together.
Torque
z33_img_g_01_01.gifPower
Kit Components- GT3037 Turbine (56T A/R 1.12)
- GT II Wastegate
- Intercooler ASSY
- Exhaust Manifold
- Adapter Flange
- Front Pipe
- Wastegate Inlet Pipe
- Front Pipe with Metal Catalyzer- Bypass Pipe
- Oil Sump
- Baffle Plate
- Chamber Pipe x 4
- Suction Pipe x 2
- Super Power Flow Reloaded
- Other parts
Remarks- Injector and fuel pump need to be upgraded. Injector (1402-RN011), Fuel Pump (G23210-K00010-00) are recommended.
- F-CON V Pro is required for engine management.
- Factory setting of Wastegate is at 0.35kgf/cm2. Boost limitation of stock engine is 0.4kgf/cm2. In order to increase boost level more, upgrading of engine internal parts is required.
The next generation forced induction system "GT SUPERCHARGER". It is high balance of Power and environmental performance.The next generation quality of acceleration feeling from HKS GT SUPERCHARGER.
New HKS GT SUPERCHARGER has "Quick acceleration response without lag", "Linear torque characteristic at low and middle rpm", "Low mechanical noise and compact design", "Environmental performance" like economical fuel consumption and clean exhaust gas.
sc_img_03.jpgsc_img_04.jpg* The engine cover is not included in the kit as it is option item. Explanation of GT SUPERCHARGER SYSTEM-Complete Kit includes all parts required for installation and operation (*1). No modification is required for installation. It's "Quiet" and "High Power".
-Complete Kit includes engine management system. HKS or stock exhaust and stock catalytic converter are specified.-Pro Kit does not include Fuel parts and engine management system. It can be used at high horsepower with engine internal upgrading.
* 1 : Spark Plug is not included. Select proper one for vehicle.
HKS' recommendation : HKS SUPER FIRE RACING M40IL (50003-M40IL)
Kit Components
Complete Kit
Pro Kit
- GT Supercharger Unit
- Intercooler
- Injector
- Fuel Pump
- Piggy back ECU
- Supercharger Bracket
- Pulley, Belt- Super Power Flow
- Suction Pipe
- Chamber Pipe
- Relief Valve
- Traction Oil Cooler
- Traction Oil Tank
- Traction Oil - GT Supercharger Unit
- Intercooler
- Suction Pipe
- Chamber Pipe
- Relief Valve
- Traction Oil Tank
- Traction OilCombine with parts listed below due to preset data of included sub computer.- The use of parts which are not listed will void warranty.- There is a risk of damaging the engine if parts other than the ones listed are used.
Parts required for Complete Kit
ECUStock ECU with factory dataCatalytic ConverterStockExhaust ManifoldStock or HKS Stock Replacement Type Stainless Exhaust Manifold Center PipeStock or HKS Stainless Center Pipe
MufflerStock or HKS LEGAMAX
(Full Dual Muffler or LEGAMAX Premium are also included for FAIRLADY Z.)
Spark PlugHKS SUPER FIRE RACING M40iL / M45iL or S40iL / S45iL
Engine OilHKS SUPER TURBO RACING
HKS SUPER Premium RACING
HKS SUPER TURBO RACING Pro HKS SUPER TURBO RACING Special
HKS Premium Pro If the Complete Kit is used in ways listed below, it will void the warranty.
Usage which will void warranty
Driving on track under constant high load.Changing or adjusting data on the sub computer.Changing the ECU data. (Increasing maximum rpm or changing ignition settings.)
Edited by Martin HKS
For some reason I can't seem to download the pages correctly onto here. It keeps screwing them up. I can't even load the page and pics of the HKS twin turbo setup kit at all (I must be stupid or something).
If you guys are interested in the HKS items shoot me an email and I'll send the files through. My email is [email protected]
Hope I can help.
Cheers
Marty
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
